#thumbsup! thanks for sending those over
transom trim tabs with water pickups
im assuming the ones with struts are for dual prop jobs? flex shaft and prop mount behind the rudder?
Originally posted by JE RC PRODUCTS View PostYep Guys Harry sent me this and asked to put it out there.
Only pics sent to dealers
Here is a taste
And also a strut with a skeg.
And Inline strut and rudder.
Will have in stock after Holidays
Tim
just read the rest of this, yes chine walk, got it on the incorrect depth of stinger. all clear
Originally posted by tlandauer View PostI don't have the Spartan, sorry.
Aren't there any nice upgrade hardware for this boat?
Honestly if you bought it new, I would run it bone stock and start from there. Don't think the water cooling will give you problems on a single pick up. , just do a "walk-around" check before maiden, make sure all the lines ( tube) are connected and no leaks from the motor jacket "o'' rings etc.
Not sure what you mean by "wobble" , you are not talking about chine walk?
Chine walk is sometimes induced by incorrect depth of the stinger.
A weak servo will cause left-right instability. But any rudder that has free play between the bracket and the blade need to be checked and any loose fasteners have to be tightened, I have a TFL rudder that came with a bad bushing and it wobbles, but have not affected much of the boat's handling. just saying.....
Don't think off setting the rudder will cause any wobble. Someone will chime in hopefully.
yeah but limited on color for some of those parts. I will eventually get away from the blue and go "chrome" with the attachments in the rear. he does have some nice upgrades tho.
Originally posted by montymike View PostKintec racing sells upgrade parts
. I run my stock chine walks
a little, on6s my friend has one that does not. Came from factory perfect rare
They sell a rudder that u have to mod. They say helps. Good luck
