Mono hull center of gravity
  • DeltaForceMan
    Old No 7
    • Dec 2014
    • 101
    I've read online that the center of gravity for a mono hull can be found 25-35% of the hull measured from the transom, is this accurate?
    Good times had by all!
    I use 30% as my bench mark and typically go to 28%, haven't gone the other way though.
    • Doug Smock
      • 5359
      You'll certainly find the CG between 25 and 34% although chances are at 25% you won't keep it on the pond, and at 34% it will most likely run wet.
      When I build one I do it in such a way that I can adjust the CG between 28 and 30% by moving the batteries.
      Doug
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • DeltaForceMan
        Old No 7
        • Dec 2014
        • 101
        Ok, thanks guys.
