Outboard on a Q mono, looking for advice
  • FE-Speedboats
    • Aug 2012
    • 54
    Hi Guys;
    Am about to mount an outboard on a 36" Q-mono, and I wonder if anyone has experience running an outboard on a mono as I have none.
    Questions like, "do I still need turn fins" come to mind.
    Any advice appreciated...
    Graham H.
    • 7512
    Hi Graham.
    What hull and what outboard?
    • FE-Speedboats
      • Aug 2012
      • 54
      Hi;
      It's an AMPs International Hobbies Baja 200s
      Putting a K&B 3.5 leg on it with FE conversion
      I have a motor cowling like the one in the pic here, but I only have Merc 350xs decals. Would like some Johnson or Yamaha decals but have no clue how to get them
      Was made by a fellow under one-time authorization from AMPs, so is a brand new hull. Unlike the photo, it is black, but still with the multi-colour metal flake
      6S 2P
      180 Amp ESC
      Am installing a 2nd servo for on-the-fly trim adjustment, which I've not seen done on a K&B leg/mount yet. Someone will have done this but I don't know who they might be
      I sure wish AMPs outboard legs were still available
      Anyway, thanks to any and all for advice, experience, do's, don't's, anything.......
      Graham
      • Darin Jordan
        • 9446
        You might consider a 7.5 sized lower. 36" is a pretty big hull for a 3.5...
        Darin E. Jordan - Renton, WA
        • FE-Speedboats
          • Aug 2012
          • 54
          Is the 7.5 leg longer than the 3.5?
          The 3.5 decision was actually advice from Mike Luszcz.
          Also, added one photo to link above
          • Darin Jordan
            • 9446
            That boat looks like it'll be fine with the 3.5...
            I think the Pro Boat Stiletto lower unit would look GREAT on there... :)
            • FE-Speedboats
              • Aug 2012
              • 54
              ProBoat leg doesn't have enough canopy/hood room for the motor, cooling lines/outlet and oil lubricator reservoir I have in mind.
              I have a PB leg on my TS3 and even that needs a hole in the canopy top to allow for the AQ 2030kv motor.
              It's a thought though, thanks.....
