Turn Fin Placement on a Hydro
  • johnl6676
    Anything R/C
    • 318
    Hi all I am building a Delta Force 34 Hydro and wondering what the best placement for the turn fin would be. I have the fin and I think I know where to put it however would like some other suggestions.
    Thanks Johnl
    JohnL6676
    Everything RC Retired don't know how I ever found time to work.
  • flraptor07
    • Aug 2013
    • 2451
    I built a DF 34 Vortex I'll get you some pics when I get home tonight.
    • flraptor07
      • Aug 2013
      • 2451
      Here's some pics, I can get more if you need them. http://forums.offshoreelectrics.com/...orce+Vortex+34
      • RayR
        @SiestaKey.calm
        • Jun 2007
        • 1518
        John,
        It would help a bunch if you told us what fin and bracket you have.
        Thanks Johnl
        • flraptor07
          • Aug 2013
          • 2451
          I used the HD turn fin bracket from Kintec.
          • properchopper
            rcgoatbuild@snotmail.com
            • 6958
            Glad I saw this thread. Been dragging my feet rigging a Vortex 34 - couldn't source a fin that I thought would be the right size (I'll admit I didn't go too far out of my way).... but the other day I was at Insane and grabbed one of these. Will need to do some trimming to the bracket and probably raise the fin in the bracket a tad. Still thinking about it
            Designed for bigger hulls, but
            sticky-taped on hull for visual :
              • 5660
              That is actually a very good turn fin as well, I bought the turn fin for my Popeye but used it on my PT 30 Stealth Hydro. On the PT it worked much better than the UL-1 fin. Check out the vid.
              http://forums.offshoreelectrics.com/...tsman-turn-fin
              I am aware that a 34" hydro is bigger.
              • johnl6676
                Anything R/C
                • 318
                Thanks all for the response. I already have a fin and bracket I got from Steve at OSE. I just need to know where on the sponson to locate it. If need be I will post a picture when I get home. I am thinking as far out as I can. The fin was a little expensive but looks awesome and is curved and machined to fit perfect.
                JohnL6676
                • properchopper
                  • 6958
                  When I install the fin on FE30's, it's spaced to the outside of the sponson. The sponson has an inside ride pad just like the Vortex34. I plan on installing the fin on my Vortex outside FWIW.
                  FE30 fin position:
                  • johnl6676
                    Anything R/C
                    • 318
                    Thanks proper chopper thats what I figured. Trying to get other opinions. My friend has your old mm. Still going strong. Thanks.
                    JohnL6676
                    • johnl6676
                      Anything R/C
                      • 318
                      JohnL6676
                      • johnl6676
                        Anything R/C
                        • 318
                        flraptor Thanks for the pictures and all I actually am building an orange one as well. Believe it or not the build looks almost the same as yours, however no graphics. They are awesome. What did you use for the decals? They look great thanks again for the info!! I will post some pictures when I get a chance a little later.
                        JohnL6676
                        • flraptor07
                          • Aug 2013
                          • 2451
                          The decals are all hand cut from some vinyl I got from my local hobby shop, it's made by Monokote and come in 5"x36" sheets all colors and the checkers too. I usually line my turn fin up with the outside edge of the ride pad and up about 3/16 from the bottom.
                          • johnl6676
                            Anything R/C
                            • 318
                            Ok great thanks for the reply I think I might try that.
                            JohnL6676
