Hull recommendation - Single or Twin Catamaran?
  • Dashunde
    • Sep 2014
    • 53
    Hi all, I'm new tow boats, but not r/c or electric stuff, and I want to build my first boat.
    I have a new Leopard 4074 2200kv that I was going to use in a Villain Ex conversion, but now after getting seduced by a bunch of youtube videos I'd rather use that motor in a nice cat build.
    (The Villain will be a beater built with used/cheap stuff for the kids)
    I'm looking for hull recommendations (and build threads?) for a single cat and a larger twin motor cat that would be suitable for a pair of those Leopards each powered by a pair of 2s 40c 5000's (4s).
    Normally I wouldn't build around a motor, but a 4074 is about as far as I can go with 4s, and I want to stick with 4s because I already have a pile of fairly new GensAce 2s 5000's from my 1/8 scale cars.
    Don't plan on racing it in any class and I have a few large lakes around to run it on.
    Thanks for your thoughts.
  • Luck as a Constant
    Make Total Destroy
    • Mar 2014
    • 1952
    Depends what you wanna do with it. Turn or no turn lol
    Your motor would do nice in a mean machine cat hull and turn very well. Properly setup you can hit 50 and above on 4s.
    That's all the advise I'll give because I've had that exact boat and motor.
    Good luck on your build
      • 7990
      Your motor will not be appropriate for 6S, but you can certainly run three 2S packs in series for 6S. Just another option if you want to run a boat over about 34".
        A 32" rivercat would be a nice candidate also. They come in full carbon fiber or white gelcoat fiberglass. Here's one i built for a guy a few weeks ago. It had a very mild prop, 1800kv motor, 6s and I was not getting on it hard because it wasn't mine and I don't beat on other people's stuff. This is a very beautiful little hull.
        And here's a pic.
        • Dashunde
          • Sep 2014
          • 53
          I really like that Rivercat.. its definitely on the right track.
          I dont mind running 3x 2s bricks for 6s in a single drive I suppose, but 6 of them in a twin would get to be be a pain, no?
          Not real sure if I can get away with running 6s on that Leopard like folks are with the Neu 1515? Has anyone done it? What prop?
          I've been looking at their 37" shocker, but I'm not sure it would be worth doing twins on 4s? Comments welcome here..
            For your first boat, keep it simple. The rivercat is actually something you could grow with too. I have not reached its speed limit yet. I think it still has about another 5-7mph more I can get out of it. Check the builds section...I've built a couple. Well more than a couple lol. It's my favorite small hull. It's seems to do it all fairly well. There are cats than turn much better but most are hard pressed to attain the speeds this one can (I'm not saying I have the fastest boat in the world by any means and there always some exceptions). There are other good choices for you for sure, but this one seems to fit with what your working with. The shocker is on the large side and I really love that hull (had one) but you'd need to run twins in that one. I'd start out simple.....work your way up. That's my best advice.
            • olwarbirds
              Magic Smoke Wizard
              • Oct 2012
              • 1136
              I have run the 4074 2200kv on 6S and many other 2200kv and up motors. But, these are "SAW" setups not made to go do laps around lake. As fluid said 4S is plenty for that motor in a nice hull like the rivercat...
                Here is my rivercat with a 1515 castle, 2200kv on 4s. Keep in mind, this was the first time I ran it, the prop was not optimal and the strut setting was way off. I didnt know near what i do now and i was pretty new at this. Btw, I would not run that leopard motor on 6s. In my opinion from having disassembling numerous motors, including leopard, the build quality does not look like it hold up to that kind of rpm for any amount of time. That's just my experienced guess. It may work fine, only one way to find out....or not...lol
                • Dashunde
                  • Sep 2014
                  • 53
                  Thats not too bad for 4s. What prop was that running Travis?
                  It appears I can run 6s occasionally... but shouldn't make a habit of it, or if I do I should not steadily hammer on it..
                  I want a nice build, but I'm not going chase every mph.
                  I'm not too worried about the added complexity of a slightly larger twin, it appears to just cost more for the most part and takes more time to build.
                  I really like that there is no prop walk, the torque is neutralized, the cog is lower and the rudder becomes a center line unit.
                  Overall, it becomes more "scale" looking with twin struts. It'll sit in its stand at home as a decoration 99.9% of the time...
                  I'm also wondering about running the 32" Rivercat on a pair of large 28mm or small 36mm motors on 6s using 3x 2s 5000's that are shared by both motors?
                  Is the 32" hull even capable of taking motors down in the sides? Is there good access to those areas?
                  Ok... so the Rivercat is a great option for speed.
                  How about a similar boat that'll be a bit slower, but will turn hard? The Mean Machine was mentioned above... any other thoughts on that one?
                    That was an x642 not detounged. Mean Machine would be a good choice also, based on what I've seen on here. Cant comment from personal experience on that hull as I've never owned one..
                      Make Total Destroy
                      • Mar 2014
                      • 1952
                      Here's mine running castle 2200 on 5s. http://youtu.be/mjEqHaqyLdk
                      I do have vid of it on 4s with the leopard if you want to see that.
                      • Dashunde
                        • Sep 2014
                        • 53
                        Definitely want to see that! What prop?
                        Thanks.
                          Make Total Destroy
                          • Mar 2014
                          • 1952
                          On 4s I ran m445
                          The above vid is m440
                            Make Total Destroy
                            • Mar 2014
                            • 1952
                            Skip to 1:07 for mean machine.
                            Sorry bout the music lol
                            • Apophis
                              Space Cadet
                              • Jun 2013
                              • 142
                              What's wrong with the music?
                              Perspective
