Hull size for Neu, Fiegao, KB45 motors
  • ReddyWatts
    • 1756
    Someone asked about motor selections for hull sizes. I am trying to create a general guideline for the motors OSE sells. I know it is hard for this to cover all selections, since FE setups can be complex and extend over a wide range of extremes. Remember this is more for conservative setups to help new guys get started. Your input would be appreciated.
    hull size….. /….. Neu….. /….. Feigao.540…../…..KB45...../.....700SC...../.SV27./.Proboat./...Ammo.../.380.
    <<"-20"....../.....1506........../.......Fiegao.S......./................./................./......../............../.............../.380 L
    17”-24”…../….. 1506,1509./…..Feigao S-L…../…..N/A....../.....N/A....../.N/A./.....N/A...../.....N/A...../.N/A.
    20"-27"…../….. 1509,1512./…..Feigao L-XL../…..N/A...../.....700SC...../.SV27./.Proboat./...Ammo.../.N/A.
    24”-29”…../…..1512,1515../…..Feigao XL…../…..N/A...../.....700SC...../.SV27./.Proboat./...Ammo.../.N/A
    26”-32"…../.....1512,1515../...…Feigao XL..…/…..KB45...../.....700SC...../.N/A./.....N/A...../.....N/A...../.N/A.
    30"-36"…../….. 1515,1521./…..N/A…………./….. KB45...../..... N/A......../.N/A./.....N/A...../.....N/A...../.N/A.
    34"-42"…../….. 1521,1527. /…..N/A…………/….. KB45...../.....N/A......../.N/A./.....N/A...../.....N/A...../.N/A.
    38"-46"…../…..1527,2215. /….. N/A…………/…..N/A......../.....N/A......../.N/A./.....N/A...../.....N/A...../.N/A.
    ReddyWatts fleet photo
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    re :
    Good Stuff !! Contributions like this are really valuable Thanks Mr. Reddy !
    • lonewolf
      • Jul 2007
      • 713
      Thanks alot I am sure it will help many..................It helped me
      • ReddyWatts
        • 1756
        Do you guys think an SV or Proboat motor will push up to a 32 inch hull safely without to much heat? Has anyone run this setup? Do you think 29 inches should be the conservative maximum length?
        • johnnyoverkill
          • 295
          Blane,
          First, thank you for this list.
          Secondly, The SV27 package is very comfortable in an 29" plastic Electro V hull on 12 cells. In fact, it hauls! I think that in a heavier 29" deep V, FG hull it would start to be near the top of its safe range. Of course, lighter builds would be the exception.
          Just an old man's 2 cents...
          John
          "When too much is just right!"
          • Flying Scotsman
            Fast Electric Adict!
            • 5195
            Blane, very good info. The hard part is the number of turns on the motors and as you state without all the specifics, no can do. This will at least point people to select a motor that is suitable for their hull !! and then discuss their aims..sport or racing, power etc.
            Well done Sir.
            Douggie
            • ReddyWatts
              • 1756
              This is supposed to categorize FE motors into weight, size and heat limitations, by hull size.
              Johnnyoverkill, I changed the SV - Proboat motors to a 29 inch limit.
              Thanks for the input guys.
              • kck741
                • 282
                Okay thanks you just answered my ??? lots of help This should be a sticky
                S.S.R.C-Southern Style Radio Control
                • ReddyWatts
                  • 1756
                  Will an Ammo 2300 push up to a 29 inch hull safely without to much heat or should i change it to 27?
                  • Diegoboy
                    • Mar 2007
                    • 7443
                    If it's a light boat, It should be fine
                    • Mich. Maniac
                      • 1456
                      not trying to be a stickler but, what about 380 size motors? much testing been done with these?
                      • ReddyWatts
                        • 1756
                        I added the Fiegao 380 L motor that is for micro hulls.
                        It could also be an upgrade motor for the cheap entry level boats you can buy from Ebay.
