Phil Thomas bad hop
  • Gary
    • Jan 2009
    • 1104
    Phil Thomas bad hop
    My PT 45 just developed a bad hop at the end of a SAW run. Instead of a smooth coast to a stop she will mini hop right off the water,about 2 inches or so, real fast repeatedly and sometimes dig in and flip around. Did nothing with the strut but have done slight modes to the same props I have always run.
    The only way to control it is to verrrry slowly get off the throttle. And one more thing, I use a Castle Mamba 1/5 ESC so dont know if its slowing the prop down faster than the old hydras used to. Very strange but I can work around the problem.
    H&M 1/8 Miss Bud 73 mph
    Chris Craft 16 mph
    Some Castles can be programmed to have a delayed "brake" once the throttle is released. It is usually the aircraft controllers, maybe the Mambas too? Check the documentation.....
    • Gary
      • Jan 2009
      • 1104
      Just checked the programming and yes you can program it but I have it disabled so that is ruled out but it could be these controllers pull the motor down a little faster that the old marine esc's they sold. I will test again this Sunday to get more data on it and see.
      Chris Craft 16 mph
