Hello all, noob to this site first off. I am contemplating re-powering or replacing my Joysway wildcat. It seems to be fair value so far, (for a rtr) but just blew up (i think) my second 120A esc in this boat. oem blew the caps, the second is a venom pro 120 and had good temps on the esc, batts, and motor except the caps(they were around 180 deg). Everything else is in the 105 range. Below is the current setup vs what I'm thinking about putting in it. Anyway, any input is appreciated.
1900 kv 120A esc 6s (2) 3S 5200 stock 1.4 44mm prop, also tried x642 and a m445, but this weekend went to the water to gps and the esc crapped the bed. Acted like lost a phase but motor ohms out fine, would only "go" half throttle like LVC. esc went bonkers. No input, wont go into programming mode etc.
So I assume ESC is bad. quick calcs show setup can pull over 180 amps (5.2x35C=182 amps)
I'm looking to go with a 220 swordfish pro and possibly a 1350kv 4092.
is a 5692 too much assuming it will fit?
Thanks in advance
Thanks in advance
