Cap bank install tutorial
  • Bigsnaff
    • Jul 2014
    • 115
    I'm thinking of installing a cap bank on an old 60amp aquacraft esc. Anyone know where I can find out how to do this without blowing myself up? Thanks!!
    edit:
    Pics added down below. I'm just trying to figure out what to do with this old esc.
    It's pretty easy. Positive to positive and negative to negative. What other info you need? I just put one on my swordfish 240 last night.
    • 785boats
      Wet Track Racing
      • 3423
      This will interest you.
      http://forums.offshoreelectrics.com/...emptive-answer
        Not sure why you want a cap "bank" on an AQ 60A ESC unless you're using 12C/2200mAh cells, but here is what I did when the original cap failed. I used what I had handy, a 500uF or 1000uF would have worked fine too. Just mind the polarity. This one has been on the ESC for over two years, works great.
        • properchopper
          rcgoatbuild@snotmail.com
          • 7708
          [ATTACH=CONFIG]124718[/ATTACH]
          Same here - been beating on this for years :
          • Bigsnaff
            • Jul 2014
            • 115
            This is what I've got to work with, I got it with some other stuff I just got. (This is my first attempt at getting a pic up here!). Anyway, it looks like the cap wire burned through, but the cap looks perfect. The extra cap bank was in the bag and it's four caps of 35v 470uF. What would you guys do? Just resolder the old cap connection? Add the cap bank? Remove the old cap? I think I'm leaning towards just adding the cap bank and reconnecting the old cap, would that work? Help!
            • Peter A
              • 1622
              If you are concerned about the old cap, remove it and just use the new cap bank instead. Otherwise go with your leaning should be fine.
              • Bigsnaff
                • Jul 2014
                • 115
                Perfect! Thanks to all who chimed in! :)
