Originally posted by dethow
View Post
GPS Signal In Cabon Fiber Boats
I was just really saying that almost my entire hull is CF with only a little patch up front on the deck that is FG and the signal must be getting in through there. If you like body work and you are thinking of buying a FG hatch that you would probably end up painting. Why don't you cut like a 3"x4" oval in the top of your CF Hatch. Then on the inside of it glass in several layers of FG and maybe a little coremat (which I'll give you some). wait a day or to for it to dry. Then on the exterior of the hatch use some kind of body filler. I like Marine RX from west marine to fill in any dips. Let it dry and sand it to match. Then paint. I have access to a full paint booth right down the street from you and I and I have a nice airbrush we can use to paint it then we'll use a 2 part clear to make it look nice and pretty! Just an ideaOriginally posted by dethow View PostThanks Kaotic, but my boats are 100% CF so I don't think the signal will sneak through based on what kfxguy has said on the matter.
Michigan Fast Electric SAW Club
Revolt - 76.9mph...Building a DF35- Project Mono
Kaotic,
Thanks soooo much for the offers on several aspects. really appreciated.
I did have a thought on cutting out the CF and gluing in a piece of plexy glass from the bottom side. Then I would mount a Quanum GPS right under it so it would get signal and I could read it without removing the hatch. The Quanum is about 1" x 3" in size. But after looking at my 3 boats... this would work on the fighter cat, but the pursuit and viper do not have significant flat areas on the hatch so I would have to cut into the hull itself to do this.
Not to sure I want to do that.
On the paint... My wife's uncle does custom paint on motor cycle tanks, fenders and helmets so I plan on approaching him to do all 3 of my boats up real nice.Have fun with that....
Yeah, I've heard about the radio issue but wasn't worried since I plan on having an external antenna tube. But as I considered buying the Quanum GPS loggers I realized this could be an issue for GPS as well.Originally posted by Rocstar View PostAny conductive material such as carbon fiber will block signals like radio and GPS.Have fun with that....
I have not done this yet...but my take on it.... I feel like in a hard crash that becomes a failure point. What happens if it detaches when you have a hard slap againt the water......... guess youll find out at that point a few things.... (if the glue used holds and if not, if you put enough floatation in the hull and if your electronics are truly waterproof)Originally posted by dethow View PostDoes anyone have thoughts on the plexy glass cut out idea? Would like some pros/cons/warnings if you have any.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
Been pondering that for a few seasons, just haven't done it. Would be great to be able to see it without removing the hatch.Originally posted by dethow View PostDoes anyone have thoughts on the plexy glass cut out idea? Would like some pros/cons/warnings if you have any.My private off road rc track
Agreed... one thought I had was to use 4 to 6 small bolt/nuts to unsure the glue/epoxy does not give. The glue/epoxy basically become a water sealing agent at that point. Could have a nice finished look. I will continue to ponder and update if I decide to go down that road.Originally posted by kfxguy View PostI have not done this yet...but my take on it.... I feel like in a hard crash that becomes a failure point. What happens if it detaches when you have a hard slap againt the water......... guess youll find out at that point a few things.... (if the glue used holds and if not, if you put enough floatation in the hull and if your electronics are truly waterproof)
I like the idea, but I have so much to do already over this winter with 3 boats under construction.Have fun with that....
I would use more bolts to hold it in place, next to each other all the way around. Otherwise water will find a way in during a hard crash.Originally posted by dethow View PostAgreed... one thought I had was to use 4 to 6 small bolt/nuts to unsure the glue/epoxy does not give. The glue/epoxy basically become a water sealing agent at that point. Could have a nice finished look. I will continue to ponder and update if I decide to go down that road.
I like the idea, but I have so much to do already over this winter with 3 boats under construction."There's nothing else I really want to do other than get up and build boats." - Mike Fiore
Yep. I agree...then the holes could become ripping/cracking points. Damned if you do...Damned if you dont.Originally posted by Rocstar View PostI would use more bolts to hold it in place, next to each other all the way around. Otherwise water will find a way in during a hard crash.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
Could use an alloy/aluminum support ribbon around the interior perimeter. This would allow for the pressure from the 6 bolts to apply equal force around the entire opening. And we're only talking about a 1" x 3" cutout that would be sealed with epoxy. I think there would be a much higher risk of the entire hatch coming off if the crash was that hard. After all, were comparing a single layer of tape holding down a large hatch verses 6 bolts and epoxy holding a small piece of plexy.Originally posted by Rocstar View PostI would use more bolts to hold it in place, next to each other all the way around. Otherwise water will find a way in during a hard crash.Have fun with that....
That would work. I like Jeff's idea also.Originally posted by dethow View PostCould use an alloy/aluminum support ribbon around the interior perimeter. This would allow for the pressure from the 6 bolts to apply equal force around the entire opening. And we're only talking about a 1" x 3" cutout that would be sealed with epoxy. I think there would be a much higher risk of the entire hatch coming off if the crash was that hard. After all, were comparing a single layer of tape holding down a large hatch verses 6 bolts and epoxy holding a small piece of plexy."There's nothing else I really want to do other than get up and build boats." - Mike Fiore
The hatch is in a recess....little different than a piece of plexi bolted in from the underside. If you use an aluminum frame I think that would work.Originally posted by dethow View PostCould use an alloy/aluminum support ribbon around the interior perimeter. This would allow for the pressure from the 6 bolts to apply equal force around the entire opening. And we're only talking about a 1" x 3" cutout that would be sealed with epoxy. I think there would be a much higher risk of the entire hatch coming off if the crash was that hard. After all, were comparing a single layer of tape holding down a large hatch verses 6 bolts and epoxy holding a small piece of plexy.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
I also like Jeff's idea, but if I'm going to paint a cf piece to cover the body work I might as well just find that fg hatch somewhere.Originally posted by Rocstar View PostThat would work. I like Jeff's idea also.
I really can't believe these things are not more readily available. I have to believe a few have been lost during a hard crash to the bottom of the lake. And I've seen some body work completed on racer's hatches do to crashes with other boats.
Worst case for me is that I will purchase an entire fg hull, take the fg hatch, and then resell it with my cf hatch on the boat.
I'm just discussing the possibility of this plexy idea so I could save some money on 3 boat hatches, keep the cf look throughout, and generally think it may be cool looking.Have fun with that....
