Does anyone know if anyone has ever posted any plans, templates, or instruction for constructing the box and doing the FE conversion for the VS1? Thanks in advance for any help.
VS1 FE Conversion plans
I have a build thread on another forum if that's cool, there are different ways to do it, I left the front box intact, cut the bottom and foam out and added sides to join to the back, but you can replace the front box as well it gives you a little more room to adjust the batteries.
1/8 Miss U.S., 1/8 59 Maverick, 1/8 Executone, 1/8 Smokin Joes, MLGSX380, AC Pro40II Q Sport, AC Pro40II nitro,Twincraft mono 10s, Vision AOPC, VS1 FE, M34.
I left the front box, cut out the centre section to the 1/8 plywood motor mount sides and removed the foam, then built up the sides to meet the existing 1/8 ply at the back, used 1/16 to make to the box sides. basically a straight 2 compartment box all the way to the back of the boat utilizing as much of the existing structure for the motor mount area.
All the radio gear mounted up front, using a pull pull arrangement for steering, esc goes on a ledge I glued in right at the back, have whole centre section to move the battery back and forth. I run a 4s 5000mah pack and an Aquacraft UL-1 2030kv motor on a highly modified K&B leg. Had to use a servo extension for the esc to rx connection.If my boats upside down then who owns the one I thought I was driving the last two laps?
Actually I just found them and I have my buddy's template as well, he replaced the whole front box on his. So I guess I could trace them and mail them to you? Not sure if a scanner would keep them the right size? Or a fax?
Mine isn't perfect but I have the templates for all the little bits too.Namba District 16
Sure just send me your mailing address and I'll trace these for you. Don't worry about $$.Namba District 16
Now this is cool, how it should be and is most the time here on OSE, well done brother... DJOriginally posted by pescador View PostSure just send me your mailing address and I'll trace these for you. Don't worry about $$.Tunnels-PS295. Cats-H&M M1 Supercat Daytona rivercat. Monos-DF Cyberstorm HiTech 29. Hydros- Ms K Vac-U-Pickle Custom built 37" shovel 10th scale converted to FE Shadow. Rigger-H&M Evo II. AQ Harbortug recovery boat. Build in progress 37" cf Dragboat
if only we had more pple like this. how great it would be.Originally posted by pescador View PostSure just send me your mailing address and I'll trace these for you. Don't worry about $$.HPR 135 redemption, HPR C5009, modded zelos 36, 32 boats and counting.
They are in the mail, thanks guys but no big deal I had the stamps sitting here getting dusty.
Namba District 16
Nice conversion there.Originally posted by pescador View PostI have a build thread on another forum if that's cool, there are different ways to do it, I left the front box intact, cut the bottom and foam out and added sides to join to the back, but you can replace the front box as well it gives you a little more room to adjust the batteries.
http://www.rcsparks.com/forum/boat-b...onversion.html
I haven't ventured into the black art of tunnel racing yet. But this has me thinking now.See the danger. THEN DO IT ANYWAY!!!
