Need opinions for large project.
  • bdod
    • Jan 2014
    • 3
    Thanks for all the very informative posts. I have searched but not found anything related to my new project. I need opinions for a twin engine / drive / speed controller for a 78" large mono. It used to be single gas powered. I'm not looking to have crazy speed, just something reliable and user friendly. Thanks in advance for any input and advice.
    • 6057
    My word, 78"!!?? that outta be an attention getter at the lake
    By engines, I assume you mean electric motors. My input on this whopper:
    Motor(x2) 56x102mm with Jacket. Run it in "Y" configuration on 10s2p each motor.
    http://www.hobbyking.com/hobbyking/s...ess_Motor.html
    Motor mount(x2) http://www.offshoreelectrics.com/pro...prod=ose-80927
    ESC(x2) 240a 12s capable - http://www.offshoreelectrics.com/pro...ef-HBC0240L-CW
    Servo - This biggin is packin' 400 oz. of torque - http://www.hobbyking.com/hobbyking/s...rvo_188g_.html
    Stingers(x2) 1/4" http://www.offshoreelectrics.com/pro...os-stinger-str
    Cable(x2), I STILL dont see any large 3/16 and up cables on OSE. You need 1/4" with 1/4" shaft and at least 30" long.
    Lipos -Run it with 4 5000 mah 5 cells for each motor. 2 each in series, then paralled. So you will need 8 5s 5000 mah packs, get 40c minimum. Like these bargains:
    http://www.hobbyking.com/hobbyking/s..._5S1P_40C.html
    • olwarbirds
      Magic Smoke Wizard
      • Oct 2012
      • 1194
      Wow thats things a beast. Looks alot like a old Prather Scarab I had many years ago. Thats a nice setup already posted, only thing I would change is the servo and thats just because I prefer using waterproof savox digital, metal gear, hi-torque. I do understand your talking $100 just for this servo, but on that size hull the rudder is going to really work against the servo. Look forward to seeing a build on this on.... DJ
      • ls1fst98
        • 905
        honestly that big id stick to gas. thats a lot of boat to push around at not very fast compared to smaller boats for only 5 minutes. but....i like the idea....id personally say if you were on 10s go with twin castle 2028s and id go with more amp headroom and say sf 300s. also maybe move up to a 1/4 scale servos....not like you are tight on room.
          • 6057
          Not liking my servo choice???? LOL, yeah, it looks small in the pic, but it is alot larger than the "standard" size we use(Traxxas 2075, Futaba 3010 etc........)
          Those standard servo's are 40mm long x 20mm wide, this big'n is 68 x 30, weighs 5 times as much and puts out over twice the torque of a the powerful Traxxas 2075 standard servo.
          It is listed as a 1/5 scale, but I cant imagine one bigger, if there is post it for him!
          • bdod
            • Jan 2014
            • 3
            Thanks for the input! Unfortunately I can't run gas in the local lake, so my only option is electric. Keep those ideas coming in, I'll post progress photos when I begin.
            • Ken_NJ
              RC Boat Addict
              • Sep 2013
              • 340
              If this helps at all. I am using the motor, motor mount and ESC that Make-a-Wake mentions in my Dumas 45" Scarab that I am working on. The Scarab is 14" wide. My motor is wired in Y configuration and I'm running at 8s4p. With your boat being twice the length I'm sure with twin everything you should be good with that hardware he mentions.
              Here's a video of my boat running: https://www.youtube.com/watch?v=Z-PdL8-nNBo
              Motor 56x102mm with Jacket: http://www.hobbyking.com/hobbyking/s...ess_Motor.html
              Motor mount: http://www.offshoreelectrics.com/pro...prod=ose-80927
              ESC Swordfish Pro 240a HV: http://www.offshoreelectrics.com/pro...ef-HBC0240L-CW
              • kevinpratt823
                • Aug 2012
                • 1462
                Was thinking the same thing, maybe (2) Castle 2028, and (2) SF300, the SF300 isn't that much more than the 240HV, and it will have data logging, the only slight drawbacks are weight and size, neither of which seem like a major concern for this beast. Do you have any pics of the inside, so we can see what you're working with?
                My private off road rc track
                • bdod
                  • Jan 2014
                  • 3
                  No pics unfortunately, but beam (width) inside is about 16" and hatch length is about 22". So I have all the room in the world. The old setup had wood stringers that most likely will have to come out, but I may be able to use some of them...What were your thoughts?
                  • ls1fst98
                    • 905
                    haha not that i didnt like it but im always one to go overboard on tq for my rudders. hate to not have it turn. heres one thats 10kg more tq, it is a bit pricey. but it is a savox.
                    http://www.ebay.com/sch/i.html?_from...servo&_sacat=0
                    heres what i put in my 51 cat thats a wide boat with twins. i knew id have a positrac like affect at speed. so wanted some power.
                    http://www.amazon.com/SM-S8466M-Meta.../dp/B00DPHC9JU
                    or this one is in between the 2 and is normal sized.
                    http://www.ebay.com/itm/Savox-SA-123.../251676098498?
                    again not saying i didnt like the one you posted. just other options.
                    but as inexpensive as the one you posted is, id run two together.
                      • 6057
                      Yeah, I was goofin around about you "not liking" it.
                      That first link goes to a general ebay page, is there a different link, i would like to see that savox.
                      • kevinpratt823
                        • Aug 2012
                        • 1462
                        I'm guessing it's this one, I use it in my Losi 5ive-T, the stock servo in the truck is actually just a rebranded version of this also.....http://www.amain.com/Savox-SV-0236MG...oltage/p232354
                        • kevinpratt823
                          • Aug 2012
                          • 1462
                          I wasn't thinking anything particular, just wanted to see what you had to work with for space and access. I haven't built anything quite like this, so anything I could offer would be speculation anyway.
                          • ls1fst98
                            • 905
                            yes thats the one. it looks like a beast.
                            the wood stringers should all come out, put a cf inlay in the boat, then maybe a bulkhead up the deck somewhere once you have it all laid out. id look into some thick cf plate for the sides of the motor mounts, and possibly have a custom made mount done. thats the problem with a boat this large, everything is $$$. i went through this with wanting to do a large cat. its just more economical to do gas but in your situation its tough not allowing gas.
                            • ls1fst98
                              • 905
                              heres another thought. triples????
