Water discharge issue
  • Xcessive Carts
    • Sep 2014
    • 99
    I installed a Kenetic Dual Water Rudder on my Traxxas Spartan. Ran all new waterlines through fittings in transom, then to ESC and Motor, then out each side thru sides of hull. They put out water upto about half throttle, after that up to full speed they put out no water, I slow down and they start pouring water. Never heard of this before, can you offer some ideas?
    Sent from my iPad
  • Make-a-Wake
    FE Rules!
    • 6057
    Is the motor or ESC hot after a full pack run? If not they are working. At higher speeds the discharge turns into a spray that is hard to see.
    • Xcessive Carts
      • Sep 2014
      • 99
      They were not very warm at all.
      • Make-a-Wake
        FE Rules!
        • 6057
        If it was a hard full pack run you are good.
          • 7512
          Putting out no water might not be that accurate....on several of my boats, at slower speeds, you can see the water exiting...but as the speed increases, the water gets "flattened down" by the wind force, so it "appears" no water is coming out.
          • PowerDemon
            • 353
            When going full speed in my spartan it blows out into a mist and its very hard to see. If your temps are still ok after a hard 6S run then chances are that there is water going through the system.
            37" Fightercat Shocker powered by Neu 1530 on 10S
            • Xcessive Carts
              • Sep 2014
              • 99
              Both water lines are clear from the back to the outlet. No obstructions, have to try it again, if its not working after that, I might try to drill out the Rudder intakes. But, like postings said, just might not be able to see the mist. When I run it, and I dont see water coming out, I will keep monitoring the temps, that will tell all.
              • Spartanator
                • 1060
                What are your temps? 6s I assume?
                • properchopper
                  rcgoatbuild@snotmail.com
                  • 7708
                  I had a hard time confirming the outflow of the rear output in real time with the naked eye. A fast lens showed that it was good
                  click on picture to enlarge
                  • oscarel
                    • Dec 2009
                    • 2373
                    Do the holes in the rudder come all the way to the end? If not then you have the same issue the original Spartan rudders had.
                    • TheShaughnessy
                      • 1461
                      [ATTACH=CONFIG]121787[/ATTACH]
                      Sorry for the clutter but that is a gorgeous picture of your cheetah
                      • Make-a-Wake
                        FE Rules!
                        • 6057
                        Sure is, here, I "prettied" it up
                        • Xcessive Carts
                          • Sep 2014
                          • 99
                          Didnt have my Temp Unit with me. I will next time
