What type of bit to use to drill fiber glass?
  • HangTheMan
    • Sep 2014
    • 74
    Hi all. New to this hobby. I have to drill a hole for the antenna tube in my Genesis and Pursuit. Is there a special bit for drilling fiber glass or can I use just an standard drill bit? Also any advice or tips for drilling the hole?
    Thanks
    Dillin
    I use a nice sharp bit. Titanium even. Just go real slow to start so you do not chip the gelcoat. Sharp bit!
    • Rocstar
      Joel Mertz
      • 1536
      Use masking tape over the spot to be drilled to help keep the gelcoat from chipping. Unibits or Step bits work well.
        http://www.offshoreelectrics.com/pro...od=dh-gpmr8130
        I will not start a hole without this little handy tool. It does wonders. It was an early lesson learned from Properchopper.
          Was gonna say I use a tapered bit or uni bit.
          • HangTheMan
            • Sep 2014
            • 74
            Thank you everyone.
              This little tool prevents walking, since it is a pilot hole and it is not meant to go through the material, just the gel coat and if you want, you can go a bit deeper. It is still very necessary to gradually increase your drill bit size until your desired size is reached. A tapered bit as Travis said will eliminate these steps but my hands are not steady enough to start a hole on a powered drill, hence I love this thing.
              • rickwess
                • Apr 2013
                • 777
                I picked up a set of brad point drill bits just for drilling into these hulls.
                  I have one of those too. I use it to transfer bolt patterns
