HELP with setup for Atomik arc 58 cat
    • 6057
    How are you using a Y harness?? Its not needed at all, I cant see where u would use it with only 2 packs in series.....
    • flraptor07
      • Aug 2013
      • 2451
      Originally posted by Mr.Joshua View Post
      My "Y" harness is correct my friend. My batteries are in series.4 sure
      Still you only have 1 8s pack and that's not enough even though it's 12,000mah. Do you have any pics of your setup?
        • 6057
        Thats PLENTY of Mah raptor, I run 10,000 mah in my 60 mph 39" mono, and I ran 10,000 in my 47" mono and hit 70 mph. At 100c those batts are putting out 1200......yes 1200 continuous amps. WAY more than any boat would ever need.
        • flraptor07
          • Aug 2013
          • 2451
          What was the battery configuration?
            • 6057
            Four 5s 5000's, two each in series, then pararlleled for 10s2p 10,000 mah
            • flraptor07
              • Aug 2013
              • 2451
              There ya go, you're running 10s 2p and I'm pretty sure that would be 20,000mah
              • Mr.Joshua
                • Oct 2014
                • 41
                  Am I missing something? How is it possible that it is 20,000mah?
                  Two 5s 5000 in series =10s but still is 5,000mah, now another bank of this and the hook up is parallel, so it is 10s but now mah is doubled to 10,000mah.
                  Am I wrong? it's hot here in So Cal and was under the 100* sun testing my TFL Round Nose hydro (Libero) with e CNC M642 prop , may be I have too much exposure to the sun.....
                  • flraptor07
                    • Aug 2013
                    • 2451
                    You deffinetly got them wired right, I still think if you prop down you'll cure your problem and IMO I'd add two more packs just for run time and extra power.
                      • 6057
                      Well, your lack of Lipo knowledge has exposed your novice status as a boater. I am not going to banter with someone who doesnt even know how to figure battery capacity and voltage based on series and parallel connections, have a nice day sir.
                      Joshua, that IS series based on your pics
                      • flraptor07
                        • Aug 2013
                        • 2451
                        Never mind, my mistake you guys are right it's 10,000mah Duh! Brain fart!
                        • flraptor07
                          • Aug 2013
                          • 2451
                          [QUOTE=Make-a-Wake;591725]Well, your lack of Lipo knowledge has exposed your novice status as a boater. I am not going to banter with someone who doesnt even know how to figure battery capacity and voltage based on series and parallel connections, have a nice day sir.
                          There's no need to be a jackass about it!
                          • Mr.Joshua
                            • Oct 2014
                            • 41
                            Ok im looking at the octura x450 & x452.And the Prather s225 from OSE ? This is the cure? I know propping down is cheaper. But i still would like dependability and speed.what if i went with the more torque Leopard 56110 950kv would this motor be easier on the electronics?
                            • flraptor07
                              • Aug 2013
                              • 2451
                              I think the x452 2 blade would be fine but I always start small and work up. You need to constantly check temps while running. Start with the X450 and go to the X452 if it runs cool on the X450. I try not to run anything hotter than 130/140 deg. some people run hotter.
                              • Mr.Joshua
                                • Oct 2014
                                • 41
                                Im just worried about having another ESC failure. I've put a lot of money into this and haven't really got 2 enjoy it very much I wish my boat was as dependable as my other toysIMG_0262.jpg IMG_0272.jpg
