HELP with setup for Atomik arc 58 cat
  • flraptor07
    • Aug 2013
    • 2451
    #76
    Originally posted by Mr.Joshua View Post
    If timing advance is set to auto. What does it do?
    To tell you the truth, I'm not sure. That's why I set it manual, that way I know what the timing is.
    • Mr.Joshua
      • Oct 2014
      • 41
      #77
      So if I advance the timing to +5 deg. Is it possible I might reach 60mph ?
        I played with timing and the most I gained was .3mph....but that was my setup. In your case I still don't think you'll gain enough to surpass 60. But I will put money on it that if you switch to revolectrix batteries you will pick up about 4mph...... I remember you had maxx amps right? In my testing, they were the weakest battery I tested. Also the most expensive. The cheapest battery I tested smoked all the others. The only one that came close to revolectrix was spc. Like I said....I'll put money on it you'll go faster.....
        • Mr.Joshua
          • Oct 2014
          • 41
          #79
          I dont trust cheap Chinese batteries. Especially ones that only come with a 60 day warrantyIm a firm believer in you get what you pay for. Maxamps come with a lifetime warranty,they are 100% waterproof,And they can make custom batteries upon request. Plus i like to support my local.They are made right here in Washington state
          • Mr.Joshua
            • Oct 2014
            • 41
            #80
            Well...Sad day on our lake image.jpg The ESC caught on fireimage.jpg At least the batteries are okimage.jpgimage.jpg It blew in the first 150ft WTF?
            • Mr.Joshua
              • Oct 2014
              • 41
              #81
              Maybe I should call progressive insurance and see if the offer R/C boat insurance? That chick at swordfish owes me a new BOAT !!
                • 9481
                #82
                Good thing I was able to get that update and access my parameters the LVC was set at 2.5v per cell.That could have been bad. I set it 3.2v per cell but my run time was like cut in half .Why is that? And when I turn my boat on it beeps twice followed by 10 beeps? Shouldn't it only beep 8 times for 8s?
                its called voltage sag...
                cheap cells cannot take a big amp load without a big dump in voltage like you are seeing
                where do you think maxamps gets the cells for the packs they sell ?? (china)
                the lifetime warranty is limited and hard to claim after so many months
                and most all lipos are waterproof, meaning they can get wet
                  • 9481
                  #83
                  depends on the wind of your motor and where your esc timing is set to now...
                  Y winds do like more timing vs D winds
                  if you have a D wind, you will most likely see more heat with no performance improvements
                  • Mr.Joshua
                    • Oct 2014
                    • 41
                    #84
                    Well youre a little too late buddy .My ESC blew up today and caught my boat on fire Didnt you see the pics i just posted? That repaired ESC only lasted 7 runs
                    • paDDY
                      • Aug 2014
                      • 127
                      #85
                      Dam, sad to see that catch fire with so little use.
                        Had you listened to what we all told you in the first place, you would have not had this happen. We told you max amp batteries are garbage. In this case, you do not get what you pay for...unless your worried about an expensive warranty. I can assure you, your problem was because those batteries could not keep up with the demand.
                        • Mr.Joshua
                          • Oct 2014
                          • 41
                          #87
                          Dude the ESC FAILED!! The batteries are fine
                          • Make-a-Wake
                            FE Rules!
                            • 6057
                            #88
                            Those are odd looking connectors on your batts, wires look pretty thin too, what gauge are they?
                            • Mr.Joshua
                              • Oct 2014
                              • 41
                              #89
                              Plus if it was the maxamps fault why didn't it go up in flames on its first runs ?
                                Ok. You win. When you burn another esc up, (how many have you burnt so far?) Then maybe you'll listen and get good batteries. Notice I said good, because max amps are not good. I did back to back testing that proved it. They are the highest rated battery I tested, but by far the slowest and weakest. If you find the huge lipo test a guy did on the web, it will prove the same thing to you. It does not matter that your batteries are fine, you keep having esc failures because you choose to keep running batteries that can't keep up. I'm sorry you paid so much for them, but you need to suck it up, cut your losses and get good batteries and you'll quit burning esc's. Seems like you have it in your mind that the batteries arent the culprit.....so I wish you luck.
