jetdrive Q & A
  • hilyfe
    • Aug 2013
    • 63
    jetdrive Q & A
    Hi guys
    Im thinking of getting a new boat
    And use a jetdrive
    I have a couple questions about it
    Hopefully you guys have an answer for me
    1-where or what brand is best to buy?
    2-would it be possible to use brushed motor on a jetdrive?
    3-bigger jetdrive does it mean you have more speed?
    Thanx thats all for now
    • 7512
    1) http://www.kehrer-modellbau.de/en/
    2) Yes
    3) Maybe...depends on motor size, jet drive size, voltage, boat size etc....
    • hilyfe
      • Aug 2013
      • 63
      Hi doby
      Heres the boat im trying to get next
      46 inchess length
      Aluminum hull
      Perfect for a jetdrive
      Able to carry 6vv 12ah sla battery
      • DSC1
        • 85
        Hey I looked at that hull the Mozziecraft Ricochet. I asked them if they had any drives they recommended and they didn't. I'm waiting on my boat to be delivered. I went with a Banjee jet boat.
        Sorry to hijack your thread, but I'm also looking for motor suggestions.
        • hilyfe
          • Aug 2013
          • 63
          Its all good
          sharing information is always good
          I also asked them if they can reccomend a good jetdrive for the 46 ricochet
          And heres what they suggested
          • Peter A
            • 1622
            Something to consider is that jet units take a lot of power. My own experience a few years back with making small units and brushed motors with nicads was less than impressive. The jet unit at rcnz is designed for gas power and will take a big brushless setup to make it move. Sla batts just will not deliver. Don't be discouraged but expect to need a fair wack of power to perform.
            • hilyfe
              • Aug 2013
              • 63
              Hi peter
              Are you saying jetdrive use more energy than a regular props set up?
              Just to be clear since I want to have at least 2 hours of run time
              • Peter A
                • 1622
                Yes jet drives use a lot of power. If you are using 12 Ah batts and want 2hrs runtime then you need to draw less than 6 amps. That may work in a scale displacement hull but really isn't realistic for what you are wanting to do. If you are after long run times you may need to consider a petrol motor so you will have the power and speed required. A large brushless setup will work but you will not have more than a few minutes running on a charge.
                • hilyfe
                  • Aug 2013
                  • 63
                  Uh huh
                  Thanx for cleaning that up for me
                  I really appreciate it
                  Maybe you can tell me what type of boat electronics to have a 2 hours of run time
                  With a brushed motor
                  • TheShaughnessy
                    • 1461
                    What is speed goal. 2hrs is a lofty goal for a boat
                    • hilyfe
                      • Aug 2013
                      • 63
                      Scale tugboat speed is good enough
                      Doesn't need to be fast
                      • TheShaughnessy
                        • 1461
                        Just be prepared to have a boat full of batteries.
                        • RunningBeer
                          • Aug 2014
                          • 90
                          Hi, I've had a bit of experience building jet boats, there are a few photos of my 10s electric on my page. It has a neu22153y motor 480Kv. It accelerates extremely fast but like most jet boats sucks harder on the water with the more power applied so the top speed is only about 65Km. I only get about 5 minutes of fun out of my power combination so I guess that's not much good for you! My jet unit is a Swashdrive (56mm 3blade impellor mixed flow pump). I believe that pump is now a 'Jettec' manufactured in N.Z. Sounds like you might be planning a bit of fishing on your boat?
                          • hilyfe
                            • Aug 2013
                            • 63
                            Thats my plan fishing and having fun at the same time
                            I like those aluminum boats
                            Im pretty sure those things are sturdy
                            How about using an outboard
                            Whats the ups and downs on those outboard motors?
                            • TheShaughnessy
                              • 1461
                              Are you going to use the boat to pull the fish in or your fishing pole ?
