Need some expert help
  • vertman
    • Sep 2014
    • 14
    Newb looking for some help.
    Setup:
    Traxxas Blast
    VXL 3500 KV Brushless
    90a Hobbyking water cooled esc
    40mm trim tabs
    40 mm turn fins
    octura Y535 prop (on the recommendation of a well respected online boat retailer)
    on the factory plastic prop with no turn fins or trim tabs the boat flew on 3s but was having overheat issues with ESC (along with handling issues) so i picked up the 90a water cooled, trim tabs, prop etc.
    got it all installed today and the boat was a dog. it wouldn't plane and was slower than the factory brushed motor on nimh.
    the boat was trimmed all the way down and the tabs were set neutral. It seems the motor never got up to speed.
    before everyone says "ditch it, the blast can't handle brushless" etc, i'm well aware that this boat isn't designed and can't properly handle the power, along with the vxl being too high kv. I have basically nothing invested in this project and i'm just looking to learn and have some fun.
    do you see any obvious problems? is the prop too big? it seems big compared too the factory plastic jobby.
    I ran out of daylight to make small adjustments but it seemed like the problem was too big for a small adjustment to overcome.
    suggestions?? thanks!
  • HangTheMan
    • Sep 2014
    • 74
    Best way to find the problem is to eliminate the variables 1 at a time. Put everything back and. Ha he out only one thing at a time to see what is causing the issue. I would assume the prop so try that as the first variable.
    • HangTheMan
      • Sep 2014
      • 74
      Best way to find the problem is to eliminate the variables 1 at a time. Put everything back and change out only one thing at a time to see what is causing the issue. I would assume the prop so try that as the first variable.
      • olwarbirds
        Magic Smoke Wizard
        • Oct 2012
        • 1194
        Showing us some pics if possible is always a big help. When you say you have it trimmed all the way down, what do you mean ?
        • kevinpratt823
          • Aug 2012
          • 1462
          Did you calibrate the esc to the radio? Do you know what your low voltage cutoff is set at?
          My private off road rc track
