how large of a hole in the transom for rudder linkage?
  • jhl1963
    • Apr 2014
    • 77
    hi guys, I'm setting my linkage up (using welding rod) and the hole is constricting the throw of my rudder - - wondering how large of a hole everybody uses? Thanks
  • dasboata
    • Dec 2010
    • 3972
    You need to keep the water out I use a 3/8 hOLe and insert a Aeromarine radio box seal, to keep the water out I also for the most part use 4/40 size control rods I have seal here and I am sure OSE hgas some on there site good luck Chris
    • 785boats
      Wet Track Racing
      • 3423
      I usually glue in a piece of 1/4" brass tube & use a bellows seal over that with a small cable tie around it . That gives a decent size hole for the push rod to change angle without binding, as the servo & tiller arms travel through their arcs.
        +1!!
        Same way I do. If you line up the servo correctly, the amount the rod needs to go "wiggle" is not that much and the brass tube can act as a guild as well, as long as the rubbing/binding is not too much. ( worst case scenario).
        • dasboata
          • Dec 2010
          • 3972
          No need for brass tubing when using a Radio box seal. ???????????? KISS !!! Being that I am a old school guy, I still build today without any Metal to Metal contact the Old 75 Hertz radios would glich with any M to M contact ,, at all ! Please explain to me why you use the brass ?
          • 785boats
            Wet Track Racing
            • 3423
            Mainly for the reason that the OP wanted. A bigger hole in the transom to take up the changing angle of the push rod. But obviously a straight rod is better. But if the rudder tiller arm is close to the transom (as I've had in some boats) the rod can easily get jammed to the side of the hole st full rudder throw. Plus the boots are easier to replace when they split.
            Old habits are hard to shake aren't they. Even though you know that 2.4 gig won't be affected by any metal to metal contact/vibration.
            • dasboata
              • Dec 2010
              • 3972
              Like you said straight rods are the best and the rubber does gives no need for that much rudder travel 35-40* total degrees is all need.. anyway to each hin own , LOL on the old habits !!! I do own a bunch or 2.4 radios also LOL
              • dasboata
                • Dec 2010
                • 3972
                what is the diameter of the welding rod ?
                • rearwheelin
                  • 2101
                  Depending on how much room you have to work with and how strong is the transom the bigger the hole for me. I like to be able to pull my heavy duty ball links threw. 1/2" hole on this one :)
                  --Albert Einstein
                  • NativePaul
                    Greased Weasel
                    • 2770
                    I use a 7mm hole for the Graupner bellows.
                    • jhl1963
                      • Apr 2014
                      • 77
                      Thanks everybody, very helpful and great information - I'm using 1/8 welding rod threaded with the rod chuck (works great) to 4-40 (http://www.rodchuck.com). I have a traxxas boot which seems too small for the 1/8 rod, I will have to get an aeromarine one. I wasn't sure what size hole to drill, thanks for the tips...my hole was too small.
                      Rearwheelin - what do you use to keep water out of there?
                      Thanks
                      • dasboata
                        • Dec 2010
                        • 3972
                        I have AM seal hear cost you $9 shipped for a pair out my door today if I get paid in time use dasboata@aol.com for PP thanks chris
                        • rearwheelin
                          • 2101
                          Thanks
                          I use a finger from a latex glove . You can double up two fingers. Zip tie or safety wire .
                          --Albert Einstein
                          • siberianhusky
                            • Dec 2009
                            • 2206
                            Many moons ago when I still used to run only nitro we used part of a baby bottle nipple with brass tubing. The funky bellows were not widely available, before the days of the internet when you made do with what the LHS had in stock or waited for him to order specific parts.
                            • rearwheelin
                              • 2101
                              I like the latex glove finger because it's frictionless and free to me
                              --Albert Einstein
