Failed speed controller on my mhz mystic?
  • Fever29
    • Oct 2012
    • 34
    I recently took my boat out for testing and noticed the motors didn't sound right. Then the boat was making hard lefts at slow speed. I'm not sure if the speed controller is toast or maybe the last update I did May have caused this problem. My setup is 45 mhz mystic 2 castle 200hv ice2 speed controllers using leopard 4082 1600kv on 8s 5000 mah 65c battery's 42mm props.ill send video as soon as I figure it out thanks
    Jack
  • Fever29
    • Oct 2012
    • 34
      If you did a software update they may need recalibration.
      • Fever29
        • Oct 2012
        • 34
        I have done recalibration but not sure if I'm doing correctly. I have an older radio which is a Jr 756 PCM it has a good range and a failsafe .
        Jack
        • Fever29
          • Oct 2012
          • 34
          Just an update after a little troubleshooting I have found that one of the motors are bad. Looks like time for me to install my neu' sand see what I got. Thanks ,Jack
