neu motors question
  • meangenesracing
    • 1332
    neu motors question
    Still learning here my questions are a neu 1521 1y is 1577 kv so on 6s would be approx.34,694 rpm correct? and a 1527 1.5d is 1500 kv on 6s would be approx. 33,000 rpm correct ? so would that make much of a difference speed wise in my 43" Aeromarine conquest cat ? so which would be the best for speeds in the 70's what about a 1527 1y 1250 kv? was told in my other post for speeds in the 70s use the 1527 so how about it thanks in advance for any and all opinions
  • rearwheelin
    • 2101
    The best way do do speeds in the 70's with the 1500 series neu motors with that boat are twin setups. Unless you are a top setup master and like top of the line electrics I would consider a bigger motor that's going to have more torque with less amp draw.
    --Albert Einstein
    • madmikepags
      • Aug 2012
      • 1371
      don't run either of these in a conquest on 6S its not enuf power for this hull, a 15271.5Y on 10S or a 1530 1Y on 8S. or a Castle 2028 on 10S would really be the ticket though!!!
      We call ourselves the "Q"
        With a 1527 1250kv, you may get close or even get to your goal....but that motor may run a little hot. I had one In a 37" cat on 8s. It was probably a little faster than 70 but the temps were mid to high 120's. I'd recommend at least a 1530 for a little head room if your gonna run a single. I actually have a motor, cooler, esc, collet, flex and motor mount that will do what you want and I can make you a good deal on it. Pm me if interested
        • meangenesracing
          • 1332
          Sorry, I didn't mention that this is a twin set up
          • rearwheelin
            • 2101
            Ok it's a twin so I'm still right ha ha
            --Albert Einstein
              Well disregard my post lol
              • iridebikes247
                • 1669
                You could use the neu motor, or even 1717 castle motors. The 1717 will save you some money they can be had for a good price on ebay and with twins, 70+ is no problem at all.
                • rearwheelin
                  • 2101
                  I know a guy who has twin 1717 in his conquest and the boat is a 60 mph solid runner on 6s, he has 100's of runs with it using T180's. You can go up to 8s with 1717's.
                  --Albert Einstein
                  • meangenesracing
                    • 1332
                    I have run this boat on twin neu 1521 1y motors and it runs fine. but i would like to get just a tad more speed that is why i asked about the 1527 motors 1.5 d, or, 1y, or what and all i have are 6s batteries
                    • rearwheelin
                      • 2101
                      You need higher kv motors for 6s .
                      --Albert Einstein
                      • madmikepags
                        • Aug 2012
                        • 1371
                        If you want I have a conquest with twin 1527/1.5y's all built brand new, needs speedos and batts.
