Newbi questions
  • grayhamby
    • Mar 2014
    • 38
    Newbi questions
    I'm changing a Leecraft hull to FE. UL1 motor, Aquacraft 60 amp esc, Futaba 3PK with r603ff receiver. Wire color on esc are brown red and orange to receiver with bec capability-- where do i plug it into receiver? channel 2 is for throttle or into battery slot? There is another slot below battery slot marked rs232c ? Battery is Turnigy 5000ma 60-72C 4S. The UL 1 motor is a 36-56-2030kv 6 pole brushless . Esc to motor is red yellow black--Do I need to change leads to get proper rotation on OB? Lower unit is a modified Lawless 3.5 Will my receiver program to the esc? What beeps are heard when throttle activates? Thanks :confused graydds
  • montymike
    • 774
    1to turn 2 to burn thats how i learned it. black , brown - red+ white or orange signal Should be marked how u plug it in on receiver 1 is always to ur servo and2 to urspeed control batteries are for if you have a separate battery pack or bec. 1beep power to system pull throttle 3 beeps and should be armed motor leads should be color-coded but if you get them wrong just change the outside leads and it should be the proper rotation .mike
    • grayhamby
      • Mar 2014
      • 38
      Thanks Mike--graydds
