Which Eagle Tree
  • knpc
    • 649
    Which Eagle Tree
    As I invest more money in my boats I would like an eagle tree to test props and prevent damage to esc, motor and lipos. I'm not sure which one I need. It would be for a 29 titan with sv motor and esc and a 33 delta with 1515 1y and castle 240. How easy are the to use and hook up? Which one do I get?
    Thanks for the help
    Kevin
    Rico 29, Sprintcat 34, Insane FE 30 Hydro, 43'' Aeromarine Conquest
  • lonewolf
    • Jul 2007
    • 713
    Personally I would get the v3 hi amp version.
    Some good add ons are the brushless rpm sensor which is easy to install and easy to switch between hulls. I have a v2 which if I am correct is limited in its amperage readings. The add ons are fairly cheap. I would love a V3 now seeing I have broken the 100 amp mark. I deffinately suggest the hi amp vesrion so you can grow into it verses being limited by it... Dave
    • AntronX
      • 361
      Yep, I just got another V3 150A unit from OSE. My first one flooded with water and burned. Definitely must have tool for fast electrics. Just keep it dry :)
      • knpc
        • 649
        Thanks, that was the one I thought, it seems worth the extra $20. Could someone describe how its wired or a picture of it hooked up?
        Thanks
        • lonewolf
          • Jul 2007
          • 713
          It is hooked up inline between the cells and esc. The addons connect directly to the unit. There is also a ower panel which will let you see what is going on at the pond(very handy) and worth its weight in parts not fried.
          • knpc
            • 649
            Thanks for the info, I'll order one as soon as steven is back.
            • ED66677
              • 1300
              that's THE tool!
              Emmanuel
