What's that NOISE????!!!!!
  • Shooter
    Team Mojo
    • Jun 2009
    • 2751
    OK guys, turn your ears on! Turn up the volume! What in tarnation is this NOISE during the turns??!! It ONLY makes the noise with my new super-thin hardened stainless steel turnfin. I can turn the noise ON and OFF just by swapping fins. The most pronounced noise is at 47s.
  • dasboata
    • Dec 2010
    • 3972
    It's the boat and all it's hardware cutting threw the water. I hear it on the straights also, but it does get louder in the turns from the fin,, you might want to try the thinner Titainum fins from Randy R in Canada
    • Shooter
      Team Mojo
      • Jun 2009
      • 2751
      Thanks Chris. The odd thing is that it doesn't make any audible noise with the aluminum fin. I wonder if the SS fin is resonating when it is cutting through the water. Does steel have a lower natural freq??
      • dasboata
        • Dec 2010
        • 3972
        If you are worried about it run a support from the body to the fin see if that helps but I just think your motor is very quite !
        • Shooter
          Team Mojo
          • Jun 2009
          • 2751
          LOL. I'm not worried about it. The boat absolutely rips and holds speed in the turns. I think your support idea would tame it down for sure.....but I still don't understand what it IS?!?!
          • dasboata
            • Dec 2010
            • 3972
            you can do it a few ways I will try to find a pic
            • T.S.Davis
              • 6266
              It doesn't really do it justice in the video. It sounds like one of those silver bullet blenders vaporizing water on the way around the turn. It's kinda cool.
              It could also be the sound drop for the fighter ship Darth chases Luke with in star wars.
              Maybe that fin cuts such a crystal clean swath out of the water that you can hear it resonating. It's super thin for how rigid it is. I keep waiting for you to leave it on your table unattended. Just say'n.
              Noisy person
              • Shooter
                Team Mojo
                • Jun 2009
                • 2751
                Nice description of the noise. You can sure paint with words.
                • lt130th
                  • Apr 2014
                  • 858
                  I have nothing of technical substance to add here, except I agree that it is resonance...but I LOL'd at this.
                  • olwarbirds
                    Magic Smoke Wizard
                    • Oct 2012
                    • 1194
                    HaHaHa love the description....Shooter good name for your boat (Starwars themed) I like how it sounds, I want one.... DJ
                    • T.S.Davis
                      • 6266
                      I just watched that video again. It's almost like it gets to the end of a rubber band and then gets flung back the other way.
                      Ya know..........if that noise gets too bothersome you could just leave that fin unattended on your table and the sound will go away.......like magic..........just say'n.
                      Noisy person
                      • Doug Smock
                        • 5359
                        LOL Terry,
                        I like it, and the boats running like a raped ape. Leave it alone.
                        MODEL BOAT RACER
                        IMPBA President
                        IMPBA 19887L CD
                        NAMBA 1169
                        • Luck as a Constant
                          Make Total Destroy
                          • Mar 2014
                          • 1952
                          My ul1 used to make that noise sometimes. I always thought it was the Teflon spinning in the stuffing tube. Curious....
                          • flraptor07
                            • Aug 2013
                            • 2451
                            Sounds like a car drifting on asphalt, but it's probably the turn fin fluttering and making a audible vibration. The brace will probably cure it.
                            • longballlumber
                              • 3417
                              Just throwing ideas at it.... When was the last time you greased your flex shaft?
