Setting up ProBoat ESC
  • jcgc
    • 64
    I'm sorry if I posted this in the wrong forum, mods please move if this is in the wrong place.
    I'm trying to set up my proboat 60amp esc. I bind the receiver and controller and esc, but only the steering works. I guess I'm a little behind the times at setting up electronic speed controllers. I'm using a Futaba 3PL 3-Channel radio.
    When I turn on the receiver and esc I do not get any beeps, nada, nothing. There is power to the receiver because the steering works.
    If someone can let me know what I'm doing wrong I would greatly appreciate it.
    John
  • revoltrunner
    • May 2014
    • 646
    switch your servo reverse for the throttle and see if that works
    • revoltrunner
      • May 2014
      • 646
      you may have to push instead of pull the trigger
      • jcgc
        • 64
        Thanks for the reply Revoltrunner!!!! I tried what you said, but still nothing. I'm beginning to think this esc is defective, or I'm doing something wrong.
        • revoltrunner
          • May 2014
          • 646
          which port on the receiver do you have the esc plugged into.
          • jcgc
            • 64
            I've tried port 2 and port 3, but nothing
            • revoltrunner
              • May 2014
              • 646
              did you fully charge your batteries before trying to use it.
              your batteries may be below the low voltage cutoff.
              • jcgc
                • 64
                Hummmm, let me try that.
                • jcgc
                  • 64
                  Good news.......charged the batteries plugged everything in, pulled the trigger and the motor came to life. BUT, the motor only turns on in certain positions of the throttle trigger....ie...barely pull the trigger, motor turns on. Pull the trigger all the way back, nothing, nada, zip. Half throttle, some times the motor turns on, some times it doesn't.
                  Now I'm really stumped. I've messed with the settings on the controller, but doesn't seem to help.
                  • revoltrunner
                    • May 2014
                    • 646
                    you may have to adjust your throttle trim and endpoint
                    settings. after that I'm out of ideas.
                    • jcgc
                      • 64
                      Update: I got everything worked out, I went back and re binded the esc and controler. Now everything works as its suppose to.
                      • revoltrunner
                        • May 2014
                        • 646
                        glad it worked out for you
                        • jcgc
                          • 64
                          Thanks for the help Revoltrunner!!!!! Now I need to see if the dang thing will float and not sink.
                          • revoltrunner
                            • May 2014
                            • 646
                            your very welcome.
                            have a great weekend and keep it right side up.
