TFL Hobbies.. New Boats
    • 7277
    Originally posted by Rumdog View Post
    That's longer than I'd like.. 45" please. Still run in 6s1p per side. Around the size of the MHZ hull or HPR 115
    Wimp......
    • PowerDemon
      • 351
      I agree, something in the 45" range. Kind of like a HPR 06.
      37" Fightercat Shocker powered by Neu 1530 on 10S
      • montymike
        • 774
        Second rumdog...
        • Apophis
          Space Cadet
          • Jun 2013
          • 142
          The super daytona is 60". I would like to see a little larger Genesis/Daytona myself, 40" and a little wider so it gets a little more air under it and has more room for twins, not more than that tho, 45" can't run Q cat and for a 45" hull I would get a KBB45 :)
          Perspective
          • iridebikes247
            • 1528
            A larger genesis would be cool. Something around 42-45" with dihedral sponson design not flat ride pads. Why? The fantasm has proved itself with flat ride pads but given the speeds Shawn aka Apophis has gotten with his genesis hull I think a scaled up 45" one would be awesome. Would be nice to see a more robust looking set of drives for it.
            • Monica Smith
              • May 2013
              • 162
              Thank you for you guys actively comment and opinions. Just would like to reminding, we prefer you recommend with pictures or draft with size. If your recommendation has been used by TFL, then will have a suprise for the recommenders!
              When we are no longer able to change a situation, we are challenged to change ourselves.
              Email: monicagong76@qq.com
              • skeeler
                • Jul 2007
                • 198
                All the TFL catamarans are quite narrow and seem to be focused on straight-line speed. I'd like to see a twin cat with Mystic or MTI styling and a length-to-beam ratio of 2.75 to 3.0. Somewhere in the 34- to 36-inch size.
                Monica, here are pictures of a full-scale MTI twin cat:
                Here are images of full-scale Mystics:
                Revolt 30, River Jet, Southampton Tug, Outcast 6S BLX, 8ight-E, Ten-SCBE, 22 2.0.
                '09 Miata.
                Ibanez basses and guitars. Mapex drums, Zildjian cymbals.
                • SJFE
                  • 4735
                  I agree with skeeler 100%
                  [QUOTE=skeeler;580950]All the TFL catamarans are quite narrow and seem to be focused on straight-line speed. I'd like to see a twin cat with Mystic or MTI styling and a length-to-beam ratio of 2.75 to 3.0. Somewhere in the 34- to 36-inch size.
                  • Vin-m
                    • May 2014
                    • 308
                    the hull size that needs to be built more is the shocker hull by fightercat 95cm(37") x 28.5cm . fast boat with plenty of room to do twins. if i could find one ide buy it but they are no where to be found.
                    • rayzerdesigns
                      • Dec 2013
                      • 1228
                      i want a cart in 30 to 34 inch range but not built for straight line..say 11 to 14 inches wide
                        Agreed. It's basically a wider genesis. So shocker and mini cheetah gets my vote. Carbon and fiberglass.
                        • skeeler
                          • Jul 2007
                          • 198
                          It sounds like there are at least 4 of us (the last 4 to post) saying a wider, well-turning catamaran in the 30- to 37-inch range--the median is 33.5 inches--would be of interest. I'd be happy with either Mystic-like styling, like the Shocker or Genesis, or MTI-like styling, like the Cheetah.
                          The Cheetah is a bit wider than I'd really like, with an aspect ratio of 2.61. The shocker is at 3.33. Halfway between those is 2.97, which is in the range I mentioned before.
                          Monica, if you offer something like this, please ensure there's room in the sponsons for both motors and batteries for a twin-motor setup.
                          '09 Miata.
                          • skeeler
                            • Jul 2007
                            • 198
                            By the way, Monica, your Genesis is certainly a beautiful boat. I've been tempted by it, but I never bought one because it is a lot wider than I want. If you offered a wider twin cat that turned well, had room for motors and batteries in the sponsons, and looked as good as the Genesis, I'd be very interested.
                            Looking again at photos of the Genesis, I think I'd rather see Mystic styling than MTI styling on the boat I asked for.
                            '09 Miata.
                            • skeeler
                              • Jul 2007
                              • 198
                              Monica, you asked for drawings, so here is my best rendering of what I'd like to see:
                              I stretched the Genesis out to 325 mm wide. That gives an aspect ration of 2.89.
                              I would also be happy with something a little smaller, say 34 inches, with the same aspect ratio.
                              '09 Miata.
                              • electric
                                • 1744
                                Whatever it is, making it conform to the Namba class lengths would not hurt. No bigger than, P-class 34", Q-class 40". That applies to Hydro, Mono and Cat.
