Wiring and connectors?
  • dortoh
    Village Idiot
    • Jul 2014
    • 67
    My setup is coming together. Here is where I am for my 'power system':
    Motor - Leopard 4092/1730kv (Going for the TP4050 next)
    Batteries - 6s 2p 10,000mah
    ESC - T180 for starters till my MGM 28026-3 LITE arrives.
    I used to hard-wire everything but that's not going to happen with this application.
    So...
    I have been searching the forum trying to determine the best connectors and wire size to use when wiring the system. Going for a bulletproof setup. Search results led me to a plethora of connector options:
    8mm bullets
    6.5mm bullets
    Green Castle 6.5mm (I've herd of White Castle...yummy)
    5.5 bullets
    EC5
    Traxxas
    My over kill mentality says go 8mm bullets. But it seems they are not as widely used as some of the others.
    What would you use for connectors and wire for the above mentioned components?
    Where do you source the connectors and wire?
    Your help is greatly appreciated
    Vintage Aeromarine 29" Tunnel (converting to FE) - On the bench
    Insane FE 30 Hydro - On deck
    21' Daytona Eliminator Jet - Blown 540cid - triple digits on a good day
    Since you have a setup which can draw a lot of amperage (poor little T-180!) I'd suggest 8 to 10 ga. wire and 6.5 or 8mm connectors.
