43 " Aeromarine conquest
  • meangenesracing
    • 1332
    Originally posted by Luck as a Constant View Post
    i would grab two 1521 1577kv 8mm motors (in stock).
    I do have 3 of these motors 1521 1y with 8mm shafts just figured i would need something bigger seeing how i have 2 of them in my 36" avenger hull and it runs great.
    • don ferrette
      • 1252
      All depends on how fast you want to go. If you want to break 70 it's gonna take 1527's to get you there.
      - IMPBA Hall of Fame -
      - IMPBA Hydro Technical Director -
      • meangenesracing
        • 1332
        yes 70 something sounds good, i see a couple 1530 1y motors on here for sale but would i not need some new batteries also because all i have are 6s that would probably not do it correct ?
        • meangenesracing
          • 1332
          jay t, so if i want 70 mph what 1527 motor should i use
          2215 motors are wasted on 6S power. Several club members tried them in 6S hydros and soon replaced them with 1527s. The Conquest will work better on 1521 to 1527 motors. If you want to use easy to find L+R props (Octura x442, x447, x450/3 and x457) then choose the Kv based on the desired speed. If you want 70 mph then use the x457 props, 1527 sized motors with a Kv around 1500-1700 rpm/v.
          • rearwheelin
            • 2101
            Originally posted by Rumdog View Post
            Even twin 1515's with 447's will push the hell out of that boat.
            This
            --Albert Einstein
            • rearwheelin
              • 2101
              Twin 2200kv 1515's on 6s , 65c 5000mah batts, 2 V3's , 447's and your in the 70's easily . You can pack 4x more into this boat but it's not necessary as this hull rides very light and handles speed very good. This would be my recommendation for a great play boat.
              --Albert Einstein
