Setup question
"Hi, I am in the middle of building one and are about to finish. Here's the setup I am using:
2x Leo 3674 2200 kv
2x Seaking 120A
2x 4s1p 5000 mah
40er Prop
Once I have completed and did some test runs I am going to post some more info here!"
Posted advise:
"It is a combination, 3674 are for 150Km/h or more, this is extra weight if you plan to go at less than 90 Km/h, the same for batteries, same brand, same 'C", it is 140grs per cell.
You will carry 500grs extra weight in total , this will increase the drag and amperage.
to give you an idea, a single 350 grs motor pushes the Genesis above 100 Km/h. two motors will only help to reduce the slippage and get a better stability, but weight will increase. It is a good thinking to put less than 300 grs motors.
These motors: are good for 6s twin:: http://hobbyking.com/hobbyking/store..._Inrunner.html or Sk3 1600 kv for more speed:less weight.
Be carefull with the size of the Lipo, the floats are not so wide. Do not use less than 40Cbatteries. "
Thoughts on this advice that was posted?
2x Leo 3674 2200 kv
2x Seaking 120A
2x 4s1p 5000 mah
40er Prop
Posted advise:
