The $44 BL motor test coming up
  • sjslhill
    • 1563
    HXT 36-56 2700kv Brushless Inrunner (WaterCooled)
    Coupled with the $12.50 50 amp controller, it should be interesting. GPS and DPR recordings will be provided. Hull, 1/12 Classic Hydro on 3, A123 cells.
    Total cost $102 for batteries, motor and controller
    May be a flop, may work fine.
  • sjslhill
    • 1563
    Kv: 2700rpm/v
    Required ESC: 80A (going to try less on a smaller prop)
    Voltage Range: 10-18v (going to start at 10.0V, 3 A123 cells)
    No Load Current: 4.9A
    Max Load: 68A
    Max Power: 475W/60S
    Weight: 317g
    Shaft: 5mm
    Standard size mounting holes enable the motor to be installed in a large range of motor mounts.
    Motor has an inbuilt water jacket.
    • sjslhill
      • 1563
      Larger image
      Larger Image
      • ReddyWatts
        • 1756
        I have always been curious about that motor. Keep us updated.
        ReddyWatts fleet photo
        • Teerayoot
          • 20
          Interest for this one too ,how it fast?compare with Neu 1521??? :)
          สวัดดีครับ
          • sjslhill
            • 1563
            Thoughts
            I don't expect it to compare to the Neu motor at all. This is not an all out see which motor is the fastest on the planet test. This is a test to see how one can have fun with a lower budget.
            thanks,
            Steve
            • Spot Me 2
              • 770
              Hurry up and test that thing. I need a cheap set up for my daughters new boat. I just want to know if it goes up in smoke and if its faster than a similar brushed set up. Looking forward to the testing! Keep us posted!!!
              MMGMMarine
              RobertsonRacing
              • sjslhill
                • 1563
                It's going to be two weeks or so........I am going camping next week. Doozie is doing the same test in a mono. It's not going up in smoke, I'll fuse the system until I make sure I get it setup properly.
                If you want to run brushed, there is $31 800 motor on Amazon that will last foerever, in fact it's brushes can be changed.
                • ghostofpf1
                  • 399
                  I have that motor and ran it briefly in a 4s 33" mono.From memory it ran hotter than I expected even with the water jacket .Sorry no hard figures as I put a Feigao XL 2084kv motor in it's place soon afterwards.Still have the 36-56 motor just needs 3s lipo to keep things reasonable I think
                  HTH
                  Ghost
                  • ReddyWatts
                    • 1756
                    I agree, this motor will not compare to a Neu. It is rated at 475 watts and a 1521 will handle 2500 - 3000 watts. Watts = Power. It could be a good motor, if it can handle the heat?
                    • sjslhill
                      • 1563
                      It's a 3S motor, I don't care about what class it fits in.
                      The 1521 should be in an unlimited class, that's 4HP and complete overkill for most people. I don't need a fishing trolling motor.
                      • J Solinger
                        • Apr 2008
                        • 197
                        It's just a matter of finding out what hull size and type matches it. I will be watching too. Thank you for your testing efforts Steve.
                        Joe Solinger
                        • sjslhill
                          • 1563
                          My plan is three Classic Hydros all setup the same for Matthew, Mom and Dad (me) and Andrew in training.....if this motor does not work, I know the 800 Doozie motor will.
                          • Doozie870
                            • 970
                            Here is one with the mentioned esc, doing some real basic layout on a electrovee.Great idea Steve this is going to be fun!
                            • sjslhill
                              • 1563
                              Yes
                              As we talked, we may need to go 4S with A123 and 3S with LiPoly
                              I should have all the parts soon. Guess I need a 5mm to .125 coupler though, not sure if I have one or not.
                              Is the 700BB 5mm?
                              [ATTACH]6596[/ATTACH]
