you stated in a thread that you run your strut 3/16 off the table. kfxguy in this thread stated he is getting best results with strut lower than table. i guess what my question is: can you take 2 different props and lower the strut with the smaller prop and raise the strut with the bigger strut and obtain the same results? another words, different hulls require different strut adjustments depending on how much hull lift the boat has?
Hull design
Hull speed
Prop lifting characteristics
Prop setback from sponson transoms
CG
Etc.
For example my MC likes the strut bottom to be level with the sponsons. My SprintCat 60/80 likes it from 3/8" to 3/4" above the sponsons depending on the prop and speed. My MM likes it about 3/16". You just have to try different settings, sometimes it seems counterintuitive. Using the builds of others with the same hull and similar speeds as a reference helps....but always do some experimenting since the other guy's setup may not be optimal. Like any boat, the setup is key to success, something most seem to overlook. That's why one guy can be a lot faster than another with the same hull and gear.
