high wind
  • saleens7
    • 1130
    motor caps?
    are those capacitors?
    i think another reason why it didnt have good range was because i was running it without the deck on and the antenna didnt have a tube that it could go striat up through, but it was just lying over the side of the boat..
    • Rex R
      • 1007
      right motor caps/condensers > capacitors. heh, I suspect you're right bout the antenna :).
      • saleens7
        • 1130
        what prop would work with this setup?
        i found out that ill need to buy a 4mm prop shaft becasue the one i have doesent work with the coupler...it will need to be one of those 4mm threaded props, but i dont know what prop will work....
        the one i have seems to be around 34-36mm diameter, but it has barely any pitch compared to the 40mm prop i have for my SW36....i dont want to overprop or underprop, but i done want to buy more than one prop...i might be able to get two if im lucky, but thats it...
        any suggestions?
        EDIT: also the motor im running looks to be an 05 or 540 or some other 500 size motor..
        • saleens7
          • 1130
          anoyone know what prop i should use?
          its looks like either an 05, 540, 550, or some other type of 500 motor...i need to know what prop will be good with it..soon too, ill be ordering stuff soon and im going to need to now atleast a rough estimate of what props ill need
          • ED66677
            • 1300
            for the Speed600 7.2V, KV must be around 2520.
            Emmanuel
            • saleens7
              • 1130
              i dont have the speed 600, its some 500 size motor i pulled from my tiger drive nitro engine starter....
              i was going to get the speed 600 though, but i decided to later change to a titan motor...not right now though, i still need to know what prop for the 500 motor, and soon...atleast an estimate...
              • ED66677
                • 1300
                I think you need to get a K31 or K33, the 600 7.2V is turning a K36 (see Graupner Prop. group 601) I think the K26 or K29 are for Speed480
                I've used a Speed600 Race 9.6V @ 10.8V with watercooling, turning a K36, then gets a bit warm with a K37.5 and hot with a K39
                Emmanuel
                • saleens7
                  • 1130
                  thanks...but a bit too late, my father already ordered and he didnt have time to get the props...ill have to wait till later....so now ill have everthing ready to go except the prop....
                  ill get the 31mm and 33mm threaded 4mm shaft props..
                  • saleens7
                    • 1130
                    anyone know what the KV of the traxxxas titan motor is?
                    isnt not on the motors specs chart...
                    • SJFE
                      • 4867
                      That motors brushed. You would go by turns more than a kv rating. I think it's around 20 turns.
                      • saleens7
                        • 1130
                        how would you find rpms by turns?
                        is there a certian rpm per turn rating?
                        • RMZDADDY
                          • 395
                          Traxxas doesn't provide rpm ratings for the Titan motors. The marine titan is a 23 turn. Since it is intended to run on 14.4v in the Villain ex, I don't know if you'd get adequate rpm's on 6 cells. The 12 turn Titan for the Stampede or Rustler is intended to run on 6 or 7 cells and might be a better choice in this case. I think they are around $23.00. BTW, if you're interested, I have a Trinity monster big block 10 turn 550 I don't have any plans for, according to Trinity it will run on 7.2-14.4v. If you'd like to have it for testing I'd let you have it for free. Just realized that you previously stated your esc need 20 turn or higher, my mistake!
                          • saleens7
                            • 1130
                            i would think the titan motor would work, the traxxas runs on 12 cells, but theres 2 motors, so that makes me think that it really just uses 7.2V per motor....
                            im probably going to keep the boat like this....no point in spending too much $ on it...i still have the SW36 build to work on..
                            • RMZDADDY
                              • 395
                              Actually, The titans do get 14.4v in the villain ex, they are wired in parallel, not series, but they will run on 7.2, just at lower rpm's.
                              • saleens7
                                • 1130
                                oh....ok, then that wont work....i think ill just stick with the current motor....why waste all the time and $ on this hull when i should be on the SW36...hmmm...only a couple hundred $'s away from being able to get the charger, power source, batts, radio system, and other stuff...
