Fine design marine wrong motor help
  • Monstercat
    • Jun 2014
    • 34
    I just got a boat for FDM it was suppose to have a TP 100x40 7500 watt 1440kv motor and a 300 amp ESC. When I checked it out it has a black diamond nemesis 495/4y 1450 kv motor and a 300amp ESC. Did I get screwed ? Or is the nemesis a better motor?
    FD used to put their private labels on motors like Leopard ( Gold Nemesis) and TP ( Black Diamond) , if my memory is correct, this was the line before they started to sell TP Motor as TP brand. I like to think that this is the older TP motor. Don't hold me to it though...
    Here is an old F/S thread, post #38...
    http://forums.offshoreelectrics.com/...000-16hp/page2
    • Monstercat
      • Jun 2014
      • 34
      i talked to FD and he told me that the nemesis was a older brand of Tp motors and that the set up i have will run 86mph on 8S lipo. the nemesis is a 1440kv 6200 watt 495-4y . the newer tp motor that he told me he was going to install was a tp 7500 watt 1450KV 3y. he is still adamant about this set up running on 10s lipo with no problems but he did sent me a bigger prop x448 sharpen and balanced. do you think the different motor will help or hurt my goal of reaching 100mph?
      • champion221elite
        • Jul 2013
        • 216
        tlandauer is correct. I have one of Chris Fine's Nemesis Gold motors (Leopard) in a Sprint Cat that he "built". Long story about that, but at least the motor is holding up well. Black Diamond motors were his private branded TP motors.
        • iridebikes247
          • 1669
          the 1440kv will be better on 8s for sure. The bigger motor the tp 4070 can come with an 8mm shaft, which is awesome.
          I would press him for the 4070 with 8mm shaft. In theory it might go 100, staying on the water is a different story. I have multiple boats that run in the mid 90s, we usually bring about 4 of them to the lake at once. 100 is a lofty goal, get to 80 first.
          You might be surprised as 80 isn't exactly slow, building a boat that runs at 100 and survives multiple crashes at 100 is more of an art than anything else.
