can anyone help identify this hull?
  • ls1fst98
    • 859
    Found it locally on craigslist with no info about it.
  • revoltrunner
    • May 2014
    • 646
    that's a Prather Lap Cat. here's one
    http://www.ebay.com/itm/VINTAGE-PRAT...item540b9357f4
    • ls1fst98
      • 859
      Ah sweet! Good find and it appears I got one hell of a deal then.
      • revoltrunner
        • May 2014
        • 646
        did you get the rear cowl with it
        • ls1fst98
          • 859
          No unfortunately I did not. all I got was what you see
          • ls1fst98
            • 859
            But it was a deal I couldn't pass up.
            • ls1fst98
              • 859
              Next question would be, can it be setup as an inboard? What kind of power in either form, inboard or outboard motor. How did these hulls handle?
                • 7990
                They did not handle quite as well as most of their OPC competition, they needed a turn fin to hang on the buoys due to their relatively wide and flat sponson deadrise. I imagine this could run as an inboard, at 35" it could use either 4S or 6S power depending on the performance and run time needed.
                • ls1fst98
                  • 859
                  I'd be setting it up just for sport running. Never owned an f1 tunnel, found it local food a whopping $20 and just couldn't let it go. If anything just to put on a shelf lol
                    • 7990
                    I bet it would make a fun sport boat. Toughest part may be fitting everything in through that narrow hatch.
                    • ls1fst98
                      • 859
                      Yea that's what I'm looking at now. I could modify it, open it up a little since I have to make a cover for it anyway. Or just buy an outboard and run it that way. Never had an outboard boat so it'd be a learning curve but shouldn't be too hard.
                      • ls1fst98
                        • 859
                        I has envisioned cutting it down to more of a hydro profile and re making a cowl and hatch, so it's a super low profile.
                        • flraptor07
                          • Aug 2013
                          • 2451
                          That would be pretty cool, make it kind of a Hydro/Cat Hybrid with inboard power, say like a 1521 Neu or TP4060 or Leopard 4082 about 1600-1800kv on 6s. it should end up pretty lite and haulass!!
                          • revoltrunner
                            • May 2014
                            • 646
                            here's a photo gallery that might give you some ideas
                            http://forums.offshoreelectrics.com/...chmentid=68645
                            • ls1fst98
                              • 859
                              This is kinda what I was thinking, would be pretty cool. I was Def thinking a 40mm leopard in the 16-1800 kv range. Using a t180 or an sf220 pro.
