Finger injury from prop change
  • morewattsnow
    • Oct 2010
    • 236
    Last week I was changing a prop when I slipped and cut my left index finger on the bottom, severing the flexor tendon. Having surgery tomorrow to repair- a major deal. They cut you open to find the tendon ends and stitch them together, then you wear a splint while the tendon heals. THEN you start an intensive program of physical therapy, hoping to get as much movement as possible back into the finger. And why did it happen? I was in a big hurry to try another prop and didn't protect myself adequately. So learn from my mistake- you can SERIOUSLY injure yourself permanently this way. Now I use a partially used roll of 2" Frost king tape to hold the prop, making sure I have a good grip on it. Anyone else have a good method of holding the prop while loosening/tightening the nut?
    Fast Electrics Have A Small Carbon Wake
  • robbo1
    • 96
    I hold the drive dog with needle nose pliers while tightening or loosening the prop nut. Keeps fingers well away from the prop.
    • rickwess
      • Apr 2013
      • 777
      I always wrap the prop in a shop towel while changing it or removing the flex for greasing.
      I hope your finger heals good as new.
      • Chilli
        • 3204
        I use a towel or rag wrapped around the prop also.
        Mike Chirillo
        www.capitolrcmodelboats.com
        • TheShaughnessy
          • 1461
          Third on the rag thing
          • PowerDemon
            • 353
            Also agree on holding the prop with a rag while tightening or loosening the prop.
            37" Fightercat Shocker powered by Neu 1530 on 10S
              Perfect example of why I use the bullets with a set screw and. Luella loctite. No need to hold the prop.
              • morewattsnow
                • Oct 2010
                • 236
                I wrapped the prop in a rag- it was so sharp it cut thru 4 layers right into my finger and pop- there went the tendon (and my summer with it).
                • urbs00007
                  • Jun 2011
                  • 857
                  001.jpgI use an allen wrench screwdriver that fits the drive dog set screw. one of the precision ones that gets a good grip in the setscrew. see pic.
                  • ls1fst98
                    • 905
                    I did this exact injury with a knife in my garage. Finger snapped straight and couldn't bend it. Don't let them fool you, you need to be in physical therapy the week you have surgery. My surgeon didn't do that and scar tissue formed on the tendon and I've lost use of the tip of my left index finger. I cut both tendons and slot went through the first knuckle. I know your pain right now.
                    • ls1fst98
                      • 905
                      As a matter of fact it's almost 2 years ago to the day I did mine. I had my surgery on July 3rd.
                      • ron1950
                        • 3082
                        ditto on the shop rags
                          Leather glove? Might be a good idea for you guys......
                          • grsboats
                            • 1011
                            This is more common than we think...reason I use an old leather glove for this task! Gill
                            GO FAST AND TURN RIGHT !
                            www.grsboats.com.br
                            • ls1fst98
                              • 905
                              Look up a metal cut glove, meat cutters use them. Looks like chain mail.
