X447 to X442
  • Jareth
    • Mar 2014
    • 63
    X447 to X442
    Hello i have a X447 for my pursuit but it's too big i need an X442
    Is there a way to make it smaller?
    Will detounging help?
    Thanks
  • champion221elite
    • Jul 2013
    • 216
    What kind of shape is your X447 in? I have a S/B X442 that i could trade if your prop is in the same condition.
    • Jareth
      • Mar 2014
      • 63
      It's in good shape and it is S/B
      • champion221elite
        • Jul 2013
        • 216
        Im good with an even up trade which will save you from grinding your x447 down.
        • Jareth
          • Mar 2014
          • 63
          Pm please
          • martin
            • 2881
            Yep trade for the x442, reducing the diameter of the x447 only reduces the diameter it dosnt change the pitch as your not changing the angle of the blades.
            • Jareth
              • Mar 2014
              • 63
              Ok thanks
              • stadiumyamaha
                • 1371
                What's your setup ?
                • Jareth
                  • Mar 2014
                  • 63
                  Dr. Mad Thrust Series Motor B3682 - 1700kv
                  T180
                  X447
                  6s 4000 mah 45C
                  In the pursuit
                  • Chilli
                    • 3204
                    Cutting down a 447 down to 42 will result in more pitch than a stock 442.
                    Mike Chirillo
                    www.capitolrcmodelboats.com
                    • Jareth
                      • Mar 2014
                      • 63
                      What about detounging
                      • stadiumyamaha
                        • 1371
                        I think a 442 is too small for your set up. I would try a m445 or m545 but I was running around 30k rpm and your at 40k which is at the edge of safe for a sport runner.
                        • Jareth
                          • Mar 2014
                          • 63
                          Ok thanks
                            Detounging will help with 'all out' speed. The tounge is at a lower pitch for more bite on take off.
                            What size motor do you have in her? I run M447's on my pursuit with a 4074 2200kv on 4s. I have run it on light 5s' but should go to a M445 then.
                            • Jareth
                              • Mar 2014
                              • 63
                              The motor is 36mm
