Replacement O-Rings for the Aquacraft coolers
  • longballlumber
    • 3417
    Hey Fellas,
    I am looking to replace some 0-Rings on a couple of my Aquacraft coolers (Gold). Has anyone taken the time to see if the local hardware store has direct replacements?
    Thanks
    Mike
  • Fella1340
    • May 2013
    • 1025
    At those sizes I doubt they will have them. If you have a local hydraulics place they would be the best bet to try if you want to get them locally. I have had good luck this way over the years for any orings I have needed, just bring the old one in.
    • Alexgar
      • Aug 2009
      • 3701
      Faucet and valve orings can.be had at home depot in tons of sizes id just take one to compare these orings are not manufactured specifically for us
        They would be metric and not as easy to find. You could try o-rings from Steve for other similar o-rings. I'll check and see if I can match them up here. I have a gold cooler to try. Might be same as those thin Feigao cooler o-rings.
          Nope but, there only $6 or so for whole cooler. Check ebay if you can size it.
          • longballlumber
            • 3417
            Thanks for the replies,
            I can do all of the posted suggestions. I was just hoping that someone had already done the leg work and had a part number or size identified. I will got to the hardware store and see what I can find.
            Thanks
            Mike
            • revoltrunner
              • May 2014
              • 646
              check out martin fluid power in Michigan.
