how do you set struts on these boats? strut flat on table? then what? new to cats. do they get adjusted like hydros?
fiberglass 37 " daytona
Yes Martin is correct but basically you will need eventually few strut adjustments to correct the riding attitude of the boat depending on the CG.The DF cats (36"and 41")I built to a friend worked good with flat struts so I guess you can start with them laying on the table and take a special attention to the COG!.GillGO FAST AND TURN RIGHT !
www.grsboats.com.br
daytona
the 37 inch daytona i built is running 64 mph with a flat strut on calm water. leopard 4082 1600 kv t-180 esc on 6-s with m445 prop. is that a good speed? would it be worth my time to blue-print the hull bottom?Originally posted by grsboats View PostYes Martin is correct but basically you will need eventually few strut adjustments to correct the riding attitude of the boat depending on the CG.The DF cats (36"and 41")I built to a friend worked good with flat struts so I guess you can start with them laying on the table and take a special attention to the COG!.Gill
I don't know too much about cat speeds but seems ok.It's always good improve hulls so the effort pays off when correctly done.GillGO FAST AND TURN RIGHT !
www.grsboats.com.br
