Dual motor setup - wiring question?
  • M3Man03
    • May 2014
    • 25
    When you have a dual motor setup in a boat (cat in my situation) and you're running 2 ESC's with 2 same sized Lipo packs, should you wire them together, or 1 pack to each ESC?
    So, to try an ASCII art illustrate:
    [ESC] [LIPO]
    [ESC] [LIPO]
    [ESC] -- [LIPO]
    [ESC] -- [LIPO]
  • champion221elite
    • Jul 2013
    • 216
    Keep them as two completely independent units. One battery powers one ESC which powers one motor. In this case, I would also be using a Rx pack instead of using a built in BEC.
      Either way works fine, just keep the wiring as short as practical. And check your racing sanctioning body to be sure you're legal.
      • Chilli
        • 3204
        If you are racing or running trials in the IMPBA the battery source must be wired together in a multi motor set up. Don't ask me why. I'm only the messenger. If you are running NAMBA or for fun, I'd keep it simple.
        Mike Chirillo
        www.capitolrcmodelboats.com
