ProBoat A3630-1500 Motor or Himax 1500kv 3630
  • icemanxo
    • Sep 2013
    • 108
    I'm going to be running one of these motors on 4s in hydro are these motors equal or is one better than the other also was going to be running 48mm prop possibly a 50mm not sure if they could handle 50mm any info would be helpful thanks for looking.
    • 9481
    I believe they are the same motors
    • icemanxo
      • Sep 2013
      • 108
      Thank you
      • JimClark
        • 5913
        they are the same motors and you can use either the probaot 1500kv or the Himax in ERCU this year
        Billy Graham
        • icemanxo
          • Sep 2013
          • 108
          Thanks for the info so basically there both the same performance
          • JimClark
            • 5913
            yup think so
            Billy Graham
              • 9481
              yeah they make them for PB
              • icemanxo
                • Sep 2013
                • 108
                Thanks for all the help appreciate the comments from everybody so I'll go with the proboat motor since it already has a cooling sleeve on it.
                • Darin Jordan
                  • 9446
                  I'm not sure that's accurate... but I can tell you that the latest Dynamite (Pro Boat) 1500KV motors are the ones you want. They are the ones you REALLY want...
                  Darin E. Jordan - Renton, WA
                    • 9481
                    Darin, I think I bought one of those from you?
                    I'm wanting to try that motor in my DF33 with a decent size prop and see how it runs on 4s
                    • Darin Jordan
                      • 9446
                      I don't think so. They have just recently come into stock... the currently stocked version is different. You can tell by the wires, and the length of the can is 56mm instead of 50mm...
                      • ron1950
                        • 3082
                        darin all I can find is this part number DYNM3835 on horizon site...the wires all look the same red white and blue type as the old ones and they give almost no details as to what the can lenth is...any suggestions?
                        • Darin Jordan
                          • 9446
                          Guys... of ALL the people NOT to trust on this site, WHY, especially on Pro Boat/Horizon Hobby matters, would you continually question ME of all people??
                          The picture on the website hasn't been updated. Please trust me. Order the DYNM3835, don't worry about the can length (it's irrelevant, as the stator/rotor aren't any longer, just lengthened to can to better accommodate the wires), shorten up the wires and add your contacts of choice. Then, go run the damn things and thank me and the guys at Dynamite after you finish... You'll find it's a much improved piece.
                          • icemanxo
                            • Sep 2013
                            • 108
                            I'll order one doesn't hurt to try, I like trying things out thanks for the help.
                            • ron1950
                              • 3082
                              darin no one is questioning you at all.....the only question asked you was is that the correct part number for the motor on horizon web site....the horizon site doesent show the new wires only the old red white and blue ones ..the site also gives no details or specs as to the can lenth....and the horizon rep was no help at all.....don't jump to conclutions when asked a simple question please....thanks for the info infact ill use one of these in the vintage 10th scale...I can use any advantage....
