Smoked it!!???
  • timtana
    • Feb 2014
    • 29
    Smoked it!!???
    Was running on the lake the other day and all of a sudden the boat stopped, brought it back in and one wire to the motor was melted, I took it home and researched further and the wire was broken, I cut it re-soldered on the connector and it fired back up, but now it seems to have too many rpm's and gets hot right away??? never got hot before even during a bench test.
    I hooked it up to the computer and check the programming on the ESC and that is fine, I have a Proboat 1500kv, Turnigy Aquastar 120 ESC and two 4s 5000 MAH running parallel, anyone know what is going on???
  • devo
    • Aug 2012
    • 156
    Any time I've seen one get hot enough to melt wires, it was toasted. Cut the heat shrink off if you havent already and see for yourself whats going on. Are the caps puffed? I wouldn't run it anymore unless you like electtrcal fires, just my .02$
    • jcald2000
      • 786
      Motor lost a phase that's why the wire melted, if you run it will take out the ESC within seconds!!!
      • timtana
        • Feb 2014
        • 29
        Thanks for the replies, going to go with a new motor maybe a leopard, anyone want to recommend what would give around the same power as the proboat, I still don't get the 2y, 3y, 4y, 6D etc.??
