MAS Epoxy curing times Q
    Just wondering when it's o.k. to take the clamps off the top skin of a Whip 40. I use MAS slow set epoxy and it's been about 19 hours since I mixed it up and started gluing down the top.
    Is it o.k. at this time to take the clamps off? I don't want to mess up anything this has been a bear to build for me.
    Just anxious to get the other side glued down tonight.
    Thanks!
  • kevinpratt823
    • Aug 2012
    • 1462
    Technical Specifications
    Mixed Viscosity w/MAS Epoxy Resin at 77 deg F: 500-600 cps
    Mixing Ratio 2:1 Resin to Hardner
    Pot Life at 77 deg F: 23 minutes
    Thin Film Set Time at 77 deg F: 5 hours
    Full Cure: 7 days
    Flash Point (closed cup): 234 degrees F
    Specific Gravity at 77 degrees F: 0.998
    Viscosity at 77 degrees F: 200
    Performance
    Flexural Strength: 14,600 psi
    Flexural Modulus: 535,000 psi
    Tensile Strength: 8,000 psi
    Tensile Modulus: 384,000 psi
    Elongation: 9 percent
    Compressive Strength: 14,000 psi
    Compressive Modulus: 384,000 psi
    Use protective gloves when working with epoxy resin systems. Use soap and water or white vinegar to clean your hands. Use Denatured Alcohol to clean your tools.
    BRAND: MAS
    Material: Epoxy
    Rate Of Cure: Slow
    Type: Hardener
    Thin film set is 5 hrs, full cure is 7 days. I can't tell you from personal experience, but this may give you an idea.
    My private off road rc track
      Thanks Kevin. I'll wait at least 24 hours to un-clamp.
