FDM speed controls
  • sapdforu
    Loose nut
    • Apr 2014
    • 88
    FDM speed controls
    Is anyone using these?
    H&M Supercat S 73mph; Daytona Twin 89.73mph
    Bandit carbon fiber Larsony, 70mph; pursuit.... too slow
  • champion221elite
    • Jul 2013
    • 216
    http://www.finedesignrc.com/speedcontrolsfdm.asp
    OP, are you referring to the item I linked above?
    If so, I would run away as fast as possible!
    I really tried to give Chris a fair shake, but the level of service I received and empty promises only gets you so far. I would look elsewhere for an esc, or anything rc related for that matter.
    You have been warned.
      • 5660
      Fair warning, but my contacts/experiences with FD was OK, I never purchased any big ticket item. I am curious as to what is inside of the heat shrink.
      • sapdforu
        Loose nut
        • Apr 2014
        • 88
        I purchased from FD several years ago, 7 or so. Cant remember anything very bad except he steered me wrong on a motor selection, but I made it work anyway. I'm just wandering about those hi amp esc's. If he wont stand behind anything then I won't do business with him.
          • 5660
          I hear you, I too was wondering about these ESC's, but I guess without solid reassurance ,no one would take a chance,lol...
          Sent from my Droid using Tapatalk 2
            • 9479
            better chance to go with what Steven sells here at OSE
              • 5660
              Yup!
              Still, I wish FD would be a bit more specific about their ESC, it seems rather odd that for a small hobby such as it is, any technical disclosure would be good for the hobby/business.
              • jcald2000
                • 768
                They look like HIifei.
                • NativePaul
                  Greased Weasel
                  • 2764
                  I'm Just guessing here, but with those ratings I suspect they could be Flier ESCs from China, also known as Alien in the UK and Fightercat in USA.
                  • Rocstar
                    Joel Mertz
                    • 1509
                    You would be correct sir.
                    • urbs00007
                      • 826
                      did they fix the problems with the flier (fightercat ) esc's. too bad fightercat failed, seemed like they were working to iron out problems and might have been able to sell reasonably priced speed controls.
                      • iridebikes247
                        • 1528
                        If you like the specs of the fightercat esc, I seriously would look into the modelbaupirate controllers. They are flier escs but are built differently, higher quality fets too I believe.
                        It would be worth a try.
                        • Gary
                          • Jan 2009
                          • 1104
                          I tried to buy the 300/400 amp from fine design and after one week I called to see where it was and he said he had gotten a bad batch of ten of them. TOTAL contradiction to what I was told when purchasing at first over the phone. And I also believe these to be Alien system ESC's but who knows.
                          H&M 1/8 Miss Bud 73 mph
                          Chris Craft 16 mph
                            alien, fightercat, and flier look to all be the same esc's. to me anyway. After all the negative I've read about fine design....I personally wouldnt give him my hard earned $$. Id look into one of the other ones. Personally I like the fightercat esc's (well the 101 anyway). I havent had bad luck with them considering. One, the receiver wire came loose which was my fault which i fixed and its still working fine. Another one I got wet which is my fault also. I have one in my shocker and it works great.
                            • Fella1340
                              • May 2013
                              • 1025
                              Not to many seem to be happy with fightercat in the long term, even the guys that wanted and tried to make them work. The modelbaupirate esc's, which are flier are being made to different specs. Lots of guys putting a pounding on them over there but I will be hanging onto my money awhile longer to see how they do.
