Added turn fins now have problems . HELP
  • rhardy60
    • Jul 2013
    • 18
    I added turn fins to my HK Quanum Aquaholic and now they're pushing the bow drown making it nose heavy at full throttle , took them off and thing are find any ideas how to fix this . Hear some pictures of the turn fins i added .
    Thanks for any help
    VXL Rustler & Quanum Aquaholic Boat + 1 Seaport Tug + Slash 4x4 platinum & Impulse31 + Atlantic Harbor Tug .
  • siberianhusky
    • Dec 2009
    • 2206
    They are mounted in the wrong spot, should be at the outside edges of the transom, mounted high enough that running straight the shouldn't be in the water, only during a turn. It's the added drag that is causing the problems.
    Could be interesting mounting them on that type of scale hull. Looks like it would be it tight space to work in back there.
    • flraptor07
      • Aug 2013
      • 2451
      Also that's too big of a fin for that hull.
        Too big, too low, causing lift. if it is running fine, why do you need them?
        • rhardy60
          • Jul 2013
          • 18
          I added them to try to stabilize the boat from going side to side . thought it might help ?
          • martin
            • 2881
            As said the fins are to big & the brackets to low causing lift, the fins need to be further out near the chines. The fins only need to be in the water when the boat banks over in a turn, where you have them all of the fin is in the water even when running straight causing drag & lift.
            • rhardy60
              • Jul 2013
              • 18
              Thanks for all the replies , with all I've seen about them i'm going to take them off . It handles great with out them other than the chine walking at high speeds .
              • Chilli
                • 3204
                Turn fin's are for keeping the stern planted in the turns. A small set of trim tabs may help with chine walk but so may a strut adjustment or CG change.
                Mike Chirillo
                www.capitolrcmodelboats.com
