TFL Pirsuit Strut Acts Like a Water Pump
    • 5660
    I didn't know the strut also leaked , I had the stinger version.
    Anyway, the Miss Excite strut looks great !
    • BILL OXIDEAN
      • Sep 2008
      • 1494
      These boats are successful, thats why I'm spending the time to upgrade it and in the process share.
      Mine runs and handles splendid, I just can't deal with the taking in water. I won with it first race against smaller boats.
      • Rumdog
        • 6453
        I'd never run the tabs flush with the bottom of the hull. Almost guaranteed to run wet.
        • jkr
          FE Addiction
          • 568
          Hello Bill.
          As Rumdog said flush tabs don't work cause they behave like extention of the hull.
          You have to plase them 1mm above.This way they work only if it is needed.
          My pursuit came with stinger and i had to seal the gap with sikaflex 221 black silicone.I like the strut you made.
          Question.
          Is your strut mounted center or offset?
          • BILL OXIDEAN
            • Sep 2008
            • 1494
            My strut is mounted center..
            Most every SAW mono I've seen has flush mounted plates.
            I've also had a boat with them above that ran awesome. Tuning option I concur..
            • BILL OXIDEAN
              • Sep 2008
              • 1494
              Originally posted by madmikepags View Post
              thats a bummer, I do hate the 2 piece drive line, but I don't feel like taking the boat apart to put in a single piece drive!!!
              In some cases a 2-piece is convenient, but not this one : )
              • BILL OXIDEAN
                • Sep 2008
                • 1494
                10401888_10152470025922148_629613535465657347_n.jpg10410455_10152470025862148_853849616771252166_n.jpg10363133_10152470026067148_7027757294277582989_n.jpg
                Moving forward with my strut upgrade, I shimmed in the proper size stuffing tube, lined it with teflon, then shrink wrapped it.
                I was able to use the stock tube support by simply shimming it with fuel tubing also acting as a vibration dampener..
                One might be concerned about such small bearings, but I run CNC aluminum props which are feather light, and ballanced a bit more precise than I've ever seen achieved with a beryllium prop thats using a manual ballancer.
                Digital on the other hand is a different story : )
                I've gotten away with using 3/16 brass props supported by 4mm bearing strut..
                  • 9438
                  Bill, do you sharpen those cnc props you show in the picture? ?The one pictured looks like it has a blunt leading edge... I sharpen mine, waaay better.
                  • BILL OXIDEAN
                    • Sep 2008
                    • 1494
                    Absolutely. I shave every one. The one pictured is brand new. I decided to use all new parts for this project. She'll be sharp as a razor before being raced : )
                    • BILL OXIDEAN
                      • Sep 2008
                      • 1494
                      Turns out, she'll hit the water today good lookin'..
                        • 5660
                        Love the wire drive, so clean looking, I like and admire the fact that you are still using the little wood support, shows the resourcefulness you have! That fuel tubing was a great idea as well. I guess I forgot, with the wire drive and the liner, what dia. of stuffing tube are you using?
                        • BILL OXIDEAN
                          • Sep 2008
                          • 1494
                          I lost my calipers, but will Definitely get back to you on that : )
                          I like to utilize as much of the rtr integrity as possible many times.
                          • BILL OXIDEAN
                            • Sep 2008
                            • 1494
                            She hit the water, and can I tell you guys she picked up at LEAST 5mph? This mod ROCKS! Getting rid of that bloody drive that comes with it is a MUST. Making the trim tabs flush helped a BUNCH as well.
                            Here's a vid : )
                            Now that I've got her figured out, I'm gonna move forward with a quality hull of the same length : )
                            • martin
                              • 2869
                              Bill vid doesn't appear to work for me.
