Warning: Undefined array key "scheme" in phar://.../vb/vb.phar/api/content/link.php on line 2 Warning: Undefined array key "host" in phar://.../vb/vb.phar/api/content/link.php on line 2 Warning: Undefined array key "scheme" in phar://.../vb/vb.phar/api/content/link.php on line 2 Warning: Undefined array key "host" in phar://.../vb/vb.phar/api/content/link.php on line 2 Warning: Undefined array key "scheme" in phar://.../vb/vb.phar/api/content/link.php on line 2 Warning: Undefined array key "host" in phar://.../vb/vb.phar/api/content/link.php on line 2 Warning: Undefined array key "scheme" in phar://.../vb/vb.phar/api/content/link.php on line 2 Warning: Undefined array key "host" in phar://.../vb/vb.phar/api/content/link.php on line 2 best way to darken epoxy? - RcBoaters Forum
    I searched around but didn't find my answer. I know there was a thread on this a while back but I had no luck finding it. I use jb weld for the mounts and stuff in my hulls. On my next build I'd like to use something black in color. Any way to darken jb weld? I think i read something about putting graphite powder in but that makes me wonder if it'll be weaker? Ideas?
  • RayR
    @SiestaKey.calm
    • 1591
    Epoxy tint.
    ACP Composites is an ISO 9001-certified custom composite manufacturer offering custom sandwich panels, laminates, shapes, and tubes, along with stock options.
    Also available at West Marine.
    • jj2003
      HIGH VOLTAGE ADDICT!
      • May 2011
      • 1710
      Here's what I used on the Daytona's. Not for JB but for epoxy.
      There are other colors as well from the seller.
      "If guns cause crime, all of mine are defective"
      45"Speedfreek
      , Fightercat #068 ​, MyYoutube Vids
        Anything I could get in town? Kind of in a time crunch.....
          This might sound crazy....rit dye maybe?
          • Darin Jordan
            • 9446
            I know that one way is to use Carbon powder... I think that's what a lot of people do when they lay up molds... Something about the black surface that helps to highlight air pockets when laying up a part.
            Darin E. Jordan - Renton, WA
              This works very well. I keep a jar of leftover carbon fiber dust from sanding and shaping parts in the past.
              • rickwess
                • Apr 2013
                • 777
                When I asked my local store they recommended epoxy pigment (http://compositescanada.com/product-...epoxy-pigments) versus graphite saying that graphite doesn't act the same as silca and weakens the joint (by how much ?????). The tint is epoxy so you would still mix with the same weight of epoxy vs hardener. You'd be surprised at how little you end up using.
                • Fella1340
                  • May 2013
                  • 1025
                  I use black epoxy dye from ACP composite. It only takes a drop or two to blacken out an ounce of resin and the colour is great. Travis, you must have a ton of carbon dust around or can make some quick if your in a pinch!
                    Yep, i do. Good idea.
                    • BILL OXIDEAN
                      • Sep 2008
                      • 1561
                      Resin pigment.
                      • sapdforu
                        Loose nut
                        • Apr 2014
                        • 88
                        Look for a glass bedding kit for rifles, sometimes they have colored powder in them. You can get stuff called epoxy black from brownells
                        H&M Supercat S 73mph; Daytona Twin 89.73mph
                        Bandit carbon fiber Larsony, 70mph; pursuit.... too slow
                        • flraptor07
                          • Aug 2013
                          • 2451
                          I always use Fine CF grindings, not only does it turn your epoxy coal black it strengthens it too..
