strut/rudder for mg 29
  • ls1fst98
    • 859
    what is a good replacement strut/rudder combo do an mg29. i took my mg to the lake wednesday night to test out the new cnc m642 prop, on my way back a guy decided to run a light and hit me almost head on and my airbag bent the strut/rudder assembly. it was i my front seat. so after my body heals ill be putting it back together.
  • macace123
    Robotics Operator
    • Mar 2013
    • 477
    i have one with the blackjack29 assembly way more adjustment on it and bolts on with same holes less hopping as-well good luck
    Its not the boat its the driver http://namba2016fenats.com/
    Whiplash,Sprint Cat, Pursuit, 83' Miss Rock modern hydro JAE21, Dragon M11 Tunnel, Mickey Beez Jet, CF JAE21
      • 9438
      I use a Speedmaster tapered rudder with home made offset and I drilled out a cheap 4mm strut to use 3/16" lead teflon bushings. Worked well enough to win a 1st last year in Michigan on stock power. The picture shows a Chinese copy of a speedmaster but, it's changed out to the real thing now.
      • ls1fst98
        • 859
        Thanks guys. Once I get this cast off my wrist I'll take a look at the speedmaster or Chinese copy.
