Need some help with the prop. Reading your message---I do have threads on the end of the shaft, but that's just for the end cap. The actual prop doesn't have threads, and is held by what I think you mean by "drive dog". Am I correct to assume I can't use the carbon props in that case?
EDIT:
On the other hand, my 4mm diameter threaded shaft is neither 1/8", nor 3/16", which makes me think that I can actually screw those cheap carbon props to the end? If this is the case, they are cheap enough, I'll be able to buy a few to experiment with.
EDIT:
