Looking for 4mm x .062 coupler
  • dahodevil
    • Oct 2012
    • 30
    I have a Leopard motor 4mm and .062 wire drive and can't find a coupler for it. Any help is appreciated.
  • ls1fst98
    • 905
    Could you use a 4mm to 3/16 prop shim, and use a 3/16 coupler? Idk if that would make it easier.
    • dahodevil
      • Oct 2012
      • 30
      good suggestion. I will search for that.
      • dahodevil
        • Oct 2012
        • 30
        I can only find the coupling in 4mm or 5mm motor shaft to fit the .062 wire drive. If I could find a 4mm ID to 5mm OD shim. Hope it would be centered if I use a shim.
        • martin
          • 2881
          If you cant find a coupling then get in touch with Jeff Wohlt at www.rcraceboat.com & he will make you a set screw type coupling to suit what ever size you need.
          • ls1fst98
            • 905
            jeff was my next suggestion. hes a member here and does excellent work.
            • dahodevil
              • Oct 2012
              • 30
              Yes, I got the wire drive from him awhile back. I'll get in touch with him. I did find K & S brass tubing 5mm Od and 4.1mm ID. you think that would work?
              • Jeff Wohlt
                • 2740
                Yes, I can make it for you.
                www.rcraceboat.com
                jwohlt5362@yahoo.com
                • dahodevil
                  • Oct 2012
                  • 30
                  Jeff. I've been eyeing the mini lathes for years and I just pulled the trigger. I should be able to make one but if I fail I'll be contacting you. Are you willing to give me any pointers?
