Pro Boat 1/12 Miss Elam
  • jcgc
    • 64
    I purchased a 1/12 Miss Elam off of ebay. The boat was originally nitro and I converted it to electric. When I received the boat it did not have a prop. I bought a X645 for the boat, but the prop shaft is way to big for the 3mm shaft on the boat. Does anyone have any advice on what size prop will fit the 3mm shaft.
  • Luck as a Constant
    Make Total Destroy
    • Mar 2014
    • 1952
    its a 1/8 shaft. you could buy a sleeve to convert the 3/16 bore of the prop, to the 1/8 pro boat shaft. a 645 is a bit big for that boat. an x440/3 and grab a sleeve and you'll be good
    • jcgc
      • 64
      Thanks for the info Luck!!!! any idea where I can get a sleeve?
        Make Total Destroy
        • Mar 2014
        • 1952
        I'm pretty sure Ose sells them now
          Make Total Destroy
          • Mar 2014
          • 1952
          here http://www.offshoreelectrics.com/pro...?prod=ose-1035
            Make Total Destroy
            • Mar 2014
            • 1952
            also the link for doing it yourself… http://www.offshoreelectrics.com/inf...propellers.php
            • jcgc
              • 64
              Your a life saver.....Thank you!!!!!!
              • Fella1340
                • May 2013
                • 1025
                You may want to think about upgrading it to a 3/16" flex shaft at some point, especially if you plan on running hard.
                • Alexgar
                  • Aug 2009
                  • 3701
                  the proboat fastech prop is 3/16 with a 3mm to 3/16 brass adapter inside
                  • Alexgar
                    • Aug 2009
                    • 3701
                    pic
                    like so it comes with the prop
